Hi
Forever some disks come up with multiple versions of the main title
I'm still mostly ripping DVD
I assume this is mostly a copy protection. Duration and segment map are different
Is there a solution to get this right more often?
I took an image that turned out to be interlaced wrong, so it flickered and looked like crap.
It's annoying to click all and sort out 4x 5GB images later.
Sorry - I can't figure out the right words to search to find an answer many must have asked before
Solution to many main movie titles? (DVD)
Re: Solution to many main movie titles?
If you don't buy Lionsgate titles, this problem is mostly moot.
But, some people seem to like movies that are distributed by Lionsgate, so they have the "pleasure" of searching through various titles to find the complete, working title.
For their DVD releases, there SHOULD be a way to tell, perhaps similar to the BD releases, but the most usual method is to search for the title and see what others have found.
paco1
Re: Solution to many main movie titles? (DVD)
Thanks I guess. I think it's more than that but will look at publisher on the next one that has this issue.
