Doctor Zhivago
jellegard
Doctor Zhivago
Post by jellegard » Sat Oct 09, 2010 7:21 pm
anyone have any luck ripping this disc? just bought it. brand new out of the box and get a posix error in chapter 20.....
setarip_old
Re: Doctor Zhivago
Post by setarip_old » Sat Oct 09, 2010 8:04 pm
Which version is it? ("Regular", "Anniversary", Region)
Submit the Debug log...
jellegard
Re: Doctor Zhivago
Post by jellegard » Sat Oct 09, 2010 8:57 pm
Anniversary edition. United States region.
the errors are at the end......
MakeMKV v1.6.0 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-868 KB19" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH10NS30 EL00" opened in OS access mode.
Optical drive "BD-ROM WD Virtual CD 1110 2003" opened in OS access mode.
Title #00054.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
File 00100.mpls was added as title #1
File 00101.mpls was added as title #2
File 00118.mpls was added as title #3
File 00121.mpls was added as title #4
File 00119.mpls was added as title #5
File 00117.mpls was added as title #6
File 00116.mpls was added as title #7
File 00120.mpls was added as title #8
Title #00000.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00060.m2ts was added as title #9
File 00026.m2ts was added as title #10
File 00063.m2ts was added as title #11
File 00064.m2ts was added as title #12
File 00065.m2ts was added as title #13
File 00066.m2ts was added as title #14
File 00067.m2ts was added as title #15
File 00027.m2ts was added as title #16
Saving 1 titles into directory /Volumes/RIPd BluRays/BluRay MKVs/Doctor Zhivago (1965)
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591774720, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591780864, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591787008, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591793152, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591799296, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591805440, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591811584, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591817728, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591823872, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591830016, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 18591836160, attempting to work around
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '18591842304'
Failed to save title 1 to file /Volumes/RIPd BluRays/BluRay MKVs/Doctor Zhivago (1965)/title01.mkv
setarip_old
Re: Doctor Zhivago
Post by setarip_old » Sun Oct 10, 2010 12:08 am
A couple of thoughts:
1) I had no problem successfully making a FULL DISC backup of this version. You might want to try doing the same - and if successful, use that as your source.
2) Although it's new, carefully examine the disc for fingerprints and/or scratches - especially near the outer edge.
3) Your drive may be beginning to fail and possibly having difficulty reading the outermost sectors.
4) You may want to try running a cleaning disc on your drive. Maxell makes one that sells for about $10U.S.
