[BUG?] MakeMKV can't stream DVDfab edited discs
kiffw
Post by kiffw » Sat Oct 09, 2010 1:48 pm
I found a problem with dvdfab edited blurays (removed trailers and menus and unused audio language). MakeMKV always says "segmentation fault" in disc mode. but stream over file mode works for this discs.
setarip_old
Re: [BUG?] MakeMKV can't stream DVDfab edited discs
Post by setarip_old » Sun Oct 10, 2010 1:56 am
Hi!
As you'll read regarding MANY programs that perform conversions of many different types, if you perform any "pre-processing", there's no way of telling what effect(s) the altered "package" may have on the behavior of the next program to use it (In this case, MakeMKV).
In other words, you shouldn't presume that MakeMKV is at fault due to changes that may have been made by DVDFab...
