Deselect closed captions when using makemkvcon
keithhelms
Post by keithhelms » Wed Nov 27, 2019 8:02 am
I've been merrily extracting dozens of DVDs using makemkvcon version 1.14.5 and then, boom, I ran into a disc that apparently has closed captioning subtitles. Makemkvcon gave me an error that it couldn't find ccextractor and aborted.
I want to extract the regular subtitles, but not the closed captioned ones. How do I modify the defaultSelection string to ignore those?
I'm using Xubuntu 18.04 and I checked and ccextractor is not in the Ubuntu repository.
keithhelms
Re: Deselect closed captions when using makemkvcon
Post by keithhelms » Wed Nov 27, 2019 8:59 am
The track selection rules supposedly support the following
N - matches if Nth (or bigger) track of the same type and language
But I couldn't find ANY examples of how to use that option. Since the closed captions were the 3rd subtitle, I figured if I could tell makemkvcon to only pull the first 2 subtitles that would get around the problem.
I tried the following combinations and all of them failed with invalid token
+sel:(subtitle*eng(2))
+sel:((subtitle*eng)*2)
+sel:(subtitle*eng*2)
+sel:(subtitle(eng|2))
+sel:(subtitle*2)
+sel:(subtitle*(2))
keithhelms
Post by keithhelms » Wed Nov 27, 2019 9:40 pm
Okay, this is turning into a PITA. I found the deb file for ccextractor in the Ubuntu 18.10 repository, downloaded it and installed it on 18.04. The install didn't give any errors and when I run ccextractor from the command line with no parameters it gives a nice long list of options. It installed into /usr/bin, so I went into the MakeMKV preferences and set the ccextractor location to /usr/bin.
Now when I try to run makemkvcon against the dvd that has closed captions, I get the following error
MSG:4041,0,2,"Failed to execute external program 'ccextractor' from location '/usr/bin'","Failed to execute external program '%1' from location '%2'","ccextractor","/usr/bin"
In my opinion, this whole feature violates the standalone nature of MakeMKV, where the install procedure includes all the commands you need to get the product to work.
keithhelms
Post by keithhelms » Wed Nov 27, 2019 9:55 pm
To end this conversation I'm having with myself, I got it working. Apparently the MakeMKV text box that prompts you for ccextractor location actually wants the ccextractor executable. I'll nitpick a little here because to me "location" means where something is, as in what directory. Even the error message "Failed to execute external program 'ccextractor' from location '/usr/bin'" LOOKS like it is trying to execute /usr/bin/ccextractor.
So now MakeMKV can waste cycles OCRing closed captions which I am not interested in in the first place, but there is apparently no way to make it NOT do that.
wmcclain
Post by wmcclain » Thu Nov 28, 2019 3:00 pm
Using /usr/bin/true as the executable dummies out the operation. Not many cycles wasted.
