I'll check this out tonight! Thanks Mike!mike admin wrote:From error log it lokks like a bad usb cable (seriously). In any case it is highly recommended to check "disable direct IO" in preferences if you are running leopard or newer.iPond317 wrote:I am having issues with a few Blu-Ray discs recently. Most recent one to give me trouble is Snatch. I am using a Pioneer BDC-202 in an external USB enclosure connected with SATA.
List of DVD/BluRay that haven't worked
iPond317
Re: List of DVD/BluRay that haven't worked
iPond317
So I tried a different USB cable and disabled the direct access under IO and now it just hangs at trying to decrypt the file /AACS/MKB_RO.inf from the disc. MakeMKV gets all the way to this one file and just hangs there. If I uncheck the disable direct access it works (fully decrypts) and will begin disc ripping but will fail and give a fatal error. Again this is for Snatch on Blu-Ray.
With direct access unchecked:
MakeMKV v1.5.2 beta darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/ianpond/MakeMKV_log.txt
Optical drive "BD-ROM OPTIARC DVD RW AD-5630A 1AHN" opened in OS access mode.
Optical drive "BD-ROM PIONEER BD-ROM BDC-202 1.07" opened in OS access mode.
Error 'Posix error - Input/output error' occured while issuing SCSI command A40..0020..07F to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:121262026
Error 'Posix error - Input/output error' occured while issuing SCSI command A30..0020..07F to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:213130789
Error 'Posix error - Input/output error' occured while issuing SCSI command A40..0020..0BF to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
Error 'Posix error - Input/output error' occured while issuing SCSI command A30..0020..0BF to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
Error 'Posix error - Input/output error' occured while issuing SCSI command A40..0020..0FF to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
Error 'Posix error - Input/output error' occured while issuing SCSI command A30..0020..0FF to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
Error 'Posix error - Input/output error' occured while issuing SCSI command A40..0020008C0 to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121261727
Error 'Posix error - Input/output error' occured while issuing SCSI command A40..0020..03F to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
Error 'Posix error - Input/output error' occured while issuing SCSI command A30..0020..03F to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
DEBUG: Code 1 at )Sw|7@%@Eju!+?U1<p:121261727
DEBUG: Code 2 at )Sw|7@%@Eju!+?U1<p:121261727
DEBUG: Code 3 at )Sw|7@%@Eju!+?U1<p:121261727
DEBUG: Code 4 at )Sw|7@%@Eju!+?U1<p:121261727
Error 'Posix error - Input/output error' occured while issuing SCSI command AD010..0800024C0 to device 'OS:IOBDServices:603b6acebb5633df:PIONEER BD-ROM BDC-202 1.07'
DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:213130835
What is your OS version and how is this drive connected (internal or USB)?iPond317 wrote:So I tried a different USB cable and disabled the direct access under IO and now it just hangs at trying to decrypt the file /AACS/MKB_RO.inf from the disc. MakeMKV gets all the way to this one file and just hangs there. If I uncheck the disable direct access it works (fully decrypts) and will begin disc ripping but will fail and give a fatal error. Again this is for Snatch on Blu-Ray.
From the log the program can't open drive device under linux. Did it ever worked for you with any other disc? Please try adding yourself to "cdrom" group.kd111 wrote:Crossing Over (region 2) won't work. I've visited the link in the log output but I thought also posting here won't hurt and might save others a purchase they can't use (yet?
CArringt
I am unable to the whole disc or even a specific stream of the new movie Star Trek (2009) Blu-ray (STARTREK11D1AC).
It keeps giving me an error.
I've tried using MakeMKV and AnyDVDHD and neither one of them work
Any ideas?
Any ideas?
setarip_old
@CArringt
Hi!
There is nothing unusual about this MKB14 BluRay disc.
1) When you have COMPLETELY EXITED AnyDVD, and use ONLY MakeMKV in "Backup" mode, what is the specific error generated?
2) Try cleaning your original, commercial BluRay disc...
Hi!
CArringt
I haven't tried to do a full Backup of the disk with MakeMKV, but I am trying that now.setarip_old wrote:@CArringt
Hi!It keeps giving me an error
Here's the log right before the rip starts
Debug logging enabled, log will be saved as /Users/atv/MakeMKV_log.txt
DEBUG: Code 4294967293 at jH<Fr0zoGJgx0fC+W%)itZfWlU/:29399128
Cannot obtain exclusive access for optical drive "PIONEER BD-RW BDR-205 1.03" - disc reading will likely fail. You may want to eject and reload the disc while makemkv is running.
DEBUG: Code 0 at jH<Fr0zoGJgx0fC+W%)itZfWlU/:213135826
DEBUG: Code 0 at <lF&V$qL:sJD{K=&:121265752
DEBUG: Code 0 at <lF&V$qL:sJD{K=&:121265016
DEBUG: Code 100864261 at u^"2<fV-WV}$[5d>v0:121263429
DEBUG: Code 100864261 at u^"2<fV-WV}$[5d>v0:29393654
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading 'BD-RE PIONEER BD-RW BDR-205 1.03' at offset '524288'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading 'BD-RE PIONEER BD-RW BDR-205 1.03' at offset '1048576'
DEBUG: Code 100864261 at u^"2<fV-WV}$[5d>v0:213132445
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading 'BD-RE PIONEER BD-RW BDR-205 1.03' at offset '32768'
DEBUG: Code 0 at V%C0>(0X+BF&}vu%ffM:29393447
Backing up disc into folder "/Volumes/MediaHD/BatchRipMovies/Star Trek (2009)"
I'll let you know what happens with the full Disc Backup. I selected "Decrypt Video" in the option. Am I supposed to do that or now.
setarip_old
This is usually indicative of a dirty or physically damaged disc...'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'
CArringt
The disc is spotless and I just watched it in my PS3
Here's the error code for the full disk backup
I'll try another disk
DEBUG: Code 0 at (F=/Ta93N#oFa``U0=&d:213138471
Backup failed-
theheath
Still receiving an error with (haven't retested all, but did retest 3 with identical results) all of my James Bond movies from The James Bond Collection
Code from Windows 7x64
Problem signature:
Problem Event Name: APPCRASH
Application Name: makemkvcon64.exe
Application Version: 1.5.2.0
Application Timestamp: 4ba37f2a
Fault Module Name: makemkvcon64.exe
Fault Module Version: 1.5.2.0
Fault Module Timestamp: 4ba37f2a
Exception Code: c0000005
Exception Offset: 00000000001c3f89
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional Information 1: a1ed
Additional Information 2: a1ed57b9eff42082aa0b23fda4a418b3
Additional Information 3: d019
Additional Information 4: d0198d0ef1cdf00cc9ff984046712f67
Thanks and good luck
Problem signature:
Locale ID: 1033
Doolittle
I've also had a problem trying to rip I'm Alan Partridge - Series 1 - Disc 1. Any help on getting this working will be most appreciated. Here was the error that I got:
MakeMKV v1.6.0 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Nutcasey/MakeMKV_log.txt
Optical drive "DVD+R-DL PIONEER DVD-RW DVR-112D BC14" opened in OS access mode.
DEBUG: Code 1073741837 at MGhrC1!/X]8'6|h30i:29395839
DEBUG: Code 1073741837 at MGhrC1!/X]8'6|h30i:121261727
Error 'Posix error - Permission denied' occurred while reading 'DVD+R-DL PIONEER DVD-RW DVR-112D BC14' at offset '1048576'
Opening files on harddrive at /Volumes/Definitely Maybe/New Decodes/IM_ALAN_PARTRIDGE/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Title #0 was added (7 cell(s), 0:28:55)
Title #1 was added (7 cell(s), 0:29:03)
Title #2 was added (7 cell(s), 0:28:59)
Title #3 was added (7 cell(s), 0:28:56)
Title #4 was added (7 cell(s), 0:28:12)
Title #5 was added (7 cell(s), 0:28:46)
Cant't locate a cell for VTS 1 TTN 7 PGCN 14 PGN 1
Cant't locate a cell for VTS 1 TTN 7 PGCN 15 PGN 1
Title #9 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 6 titles into directory /Volumes/Definitely Maybe/New Decodes
DEBUG: Code 0 at c^}YR2jd+|i0o1:;<6ZMx:213130490
DEBUG: Code 0 at c^}YR2jd+|i0o1:;<6ZMx:213129639
DEBUG: Code 0 at 3Rb:*}B3-^l|WwFu~;l:29394183
DEBUG: Code 0 at kO55^bs+-=`<^:&z>(W:29394160
DEBUG: Code 0 at kO55^bs+-=`<^:&z>(W:29395195
Failed to save title 0 to file /Volumes/Definitely Maybe/New Decodes/title00.mkv
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 2 to file /Volumes/Definitely Maybe/New Decodes/title02.mkv
Failed to save title 4 to file /Volumes/Definitely Maybe/New Decodes/title04.mkv
Failed to save title 5 to file /Volumes/Definitely Maybe/New Decodes/title05.mkv
2 titles saved, 4 failed
Doolittle
Anyone got any idea why the above error happened?
kitwingate
Serenity Blu Ray Reg. 1. No error. Creates file, but file will not play.
I have about 200 other Rips, so I'm fairly certain it's not a codec issue.
setarip_old
@kitwingate
Hi!
1) Have you burned it to disc? - If so, have you examined the burned disc for physical damage or dirt?
2) Did you make a full disc backup or a movie-only backup?
3) What have you tried playing it on?
4) Does your original, commercial Blu-ray disc play properly on the same system you used to create the copy?
Hi!
file will not play.
louisep887
Bourne Identity (2002) NTSC DVD AC3 DD5.1 - File created was 4.4GB and correct movie length but no video or audio.
__________________
Watch Life As We Know It Online Free
__________________
