The Return of the Living dead
moviebuff
Tried sending a dump for this one but wants to us microsoft email and I dont use or know how to set up but it gets this error
Cant seem to attach a dump to yahoo email?
Downloading latest SVQ(s) to C:/Program Files/MakeMKV/SVQ Directory ...
Loaded 33 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:/Program Files/MakeMKV/SVQ Directory/BD Dumps/dump_The_Return_of_the_Living_Dead_AE63A84C5BA49A18.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Re: The Return of the Living dead
Hi!
Did you do what is suggested in the next to last line that you've posted here?
moviebuff
I did but didnt see anywhere in the link for svq file from what I read 1.6 version automatically downloads the latest svq's. Unless im missing the download link on the page for latest svq's
moviebuff
So I dont see anywhere on that link with latest svq files?
setarip_old
Yes, that's what should happen. Do you have v.1.6.0 installed?
moviebuff
Yes I have that one installed and says loading 33 svq files. Guess this movie just isnt supported, unfortunately cant send dump via yahoo mail or hotmail
setarip_old
You should be able to send it, using any email service, to: svq@makemkv.com
moviebuff
in yahoo for some reason says file not supported
setarip_old
Mystifying...
BrianDW
It works now.
I want to thank the people behind Makemkv.
It's a superior product. Anytime a new 4K won't decrypt I email in the dump-file and within days it works perfectly.
Purchasing a license was a great use of $60.
