UHD blu-ray of The Patriot cannot be decrypted in the latest version of MakeMKV. I've sent the dump file to svq@makemkv.com, however the file is only 133Ko, I've tried multiple time and it is giving me the same result : 133 Ko (usually that is around 2Mo right ?). Anything I should do differently ?
Thanks a lot for the hard work to the MakeMkv Team
The Patriot UHD Blu-Ray - Cannot Be Decrypted
Re: The Patriot UHD Blu-Ray - Cannot Be Decrypted
gdievart wrote: Mon Nov 25, 2019 5:35 pm UHD blu-ray of The Patriot cannot be decrypted in the latest version of MakeMKV. I've sent the dump file to svq@makemkv.com, however the file is only 133Ko, I've tried multiple time and it is giving me the same result : 133 Ko (usually that is around 2Mo right ?). Anything I should do differently ?
The search function works really well, you know.
Anyway, this is an AACS 2.1 title and MakeMKV currently does not decrypt these.
