I have an LG WP50NB40 (slim) & a macOS computer, can I libredrive?
smokeywhitetown
My drive tells me this is possible. The main reason I wish to do this is to make the drive region-free. I'm sure I'll think of other reasons later. Thanks.
Re: I have an LG WP50NB40 (slim) & a macOS computer, can I libredrive?
MakeMKV can already work around DVD regions for most drives, without LibreDrive. LD just makes it easier.
smokeywhitetown
Thanks for your response. I had to change the DVD region on my external drive recently for use with another app, and I would like to know if I can LD this external LG burner, as I'd like it to region-free going forward.
smokeywhitetown wrote: Mon Nov 25, 2019 3:30 pm Thanks for your response. I had to change the DVD region on my external drive recently for use with another app, and I would like to know if I can LD this external LG burner, as I'd like it to region-free going forward.
Well, this works for the BP50NB40 so should also work for your WP50NB40. Requirements are:
- Windows 10 PC (a possible alternative is to download and boot into the Win10PE.iso). If you use the iso, you will need to place the WP50NB40 1.01-MK firmware on a USB thumb drive, so you can access it.
- The Modified ASUS flasher
- Firmware WP50NB40 1.01-MK
Download the Win10PE.iso from the first post of thread: https://www.makemkv.com/forum/viewtopic ... 16&t=19634 under "NS40 Recovery Image".
Let us know how you go..
smokeywhitetown
Is it possible to do this using a Mac?
