killakem
Post by killakem »
Thanks guys. It makes sense.
So which is the best device for this purpose? Shield? Purpose being playing these files with Dolby Vision and Atmos.
Many thanks
superfans124
Post by superfans124 »
justinadams wrote:
Tue Nov 19, 2019 10:59 pm
To my knowledge (someone correct me if i'm wrong) Windows does not support Dolby Vision at the point.
I vaguely remember Lenovo had (have?) a few laptop models that support Dolby Vision, but I have no idea what Dolby Vision ecosystem is like on those platforms.
zibawal
Post by zibawal »
I have LG Demo DV and also some DV Mp4 SL from torrents with DD 5.1 only. Only my oppo plays from NAS share that, not Apple TV or NVIDIA PRO
seleste
Post by seleste »
yusesope wrote:
Tue Nov 19, 2019 7:12 pm
seleste wrote:
Tue Nov 19, 2019 1:22 am
Talking about lossless audio formats....
Is there a way to mux DTS-HD MA sound in a form of .dtshd file out of DTS HD Encoder Suite, with the DV video in mp4box? Or somehow convert .dtshd to .mp4?
You should know by now. It's all written HERE.
In your specific case:
ffmpeg -i audio.dtshd -map 0:0 -c copy output_dtshd.mp4
and then use mp4box for the final mux
mp4box ............................. -add output_dtshd.mp4 .........................
@yusesope
Thanks for the suggestion, but it didn't work, please see the command and the output below.
 ffmpeg -i d:\evil.dtshd -map 0:0 -c copy d:\evil_dts.mp4
 ffmpeg version N-94652-g808a6717e0 Copyright (c) 2000-2019 the FFmpeg developers
  built with gcc 9.1.1 (GCC) 20190807
  configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt
  libavutil      56. 33.100 / 56. 33.100
  libavcodec     58. 55.101 / 58. 55.101
  libavformat    58. 31.104 / 58. 31.104
  libavdevice    58.  9.100 / 58.  9.100
  libavfilter     7. 58.101 /  7. 58.101
  libswscale      5.  6.100 /  5.  6.100
  libswresample   3.  6.100 /  3.  6.100
  libpostproc    55.  6.100 / 55.  6.100
d:\evil.dtshd: Unknown error
Angryunibrow
Post by Angryunibrow »
seleste wrote:
Sat Nov 23, 2019 4:26 pm
@yusesope
Drop your .dtshd file into MKVToolNIX and mux it as a .MKA - then run the command and it will work just fine.
DaMacFunkin
Post by DaMacFunkin »
In latest DVDfab I’ve lost the option of dual layer or single layer
Also remux subs to srt has disappeared...
yusesope
Post by yusesope »
Hello people!
As promised, I modified my app by inserting a button to switch from the active debug window to the disabled one.
I also modified the original app to make it work (I hope) also on Amazon devices (last generation).
The new version (revision November 24, 2019) works with the last server you have (take a look at THIS post), so for simplicity I will upload only the apk.
The files to be played must be prepared following the instructions of THIS post
APK for NVIDIA Shield Tv 2019
APK for Amazon devices (last generation)
In the coming weeks, I will try to implement a server discovery mechanism (to avoid having to manually change the IP address of the latter within the apk) and the possibility of exploring one or more folders directly from the application (to avoid having to specify a file each time when starting the server)
Stay tuned!
Follow Angryunibrow's advice. If it doesn't work, upload the file so that anyone who wishes could examine it.
technoobmaster
Post by technoobmaster »
cannot parse package on amazon firestick4k do you have a firestick version
baker99
Post by baker99 »
yusesope wrote:
Sun Nov 24, 2019 5:35 pm
Hello people!
Works brilliantly, thank you. Now to do some converting of my dolby vision library!
Alldu
Post by Alldu »
Hi guys,
I'd like to add the audio file to a DV mp4 which was not in the original ISO - is it possible at all? Thanks in advance!
baker99
Post by baker99 »
@yusesope the new player seems to be working but the audio is about 200ms out of sync, with my setup for regular content on the shield it's only about 75ms, it's the same on 2 films so it looks like it may just need an offset. I'm working it out by eye which isn't perfect.
I wonder if anyone else is getting this too?
seleste
Post by seleste »
Angryunibrow wrote:
Sun Nov 24, 2019 12:00 am
@yusesope
That's exactly what I did and it always worked after MKVToolNIX, just thought I'd avoid an extra step by doing a direct dtshd=>mp4 conversion.
Thanks for your response.
Grencola
Post by Grencola »
Plays on my Fire TV Stick 4k now in 2160p Dolby Vision with sound, but the framerate is stuck at 60fps. Exact same as just using MX Player :?
technoobmaster
how did you install it
Grencola
Post by Grencola »
technoobmaster wrote:
Mon Nov 25, 2019 4:45 pm
just use amazon stick's search section for an app called 'Downloader', install and open it. put in the url for yusesope's .apk and download / install it. simple :)
