Country Music - A Film by Ken Burns (tt9708550)
J392191
Post by J392191 » Sat Nov 23, 2019 4:52 pm
Can't rip DVD.
https://www.imdb.com/title/tt9708550
Here's the log when I open the disc:
MakeMKV v1.14.5 win(x64-release) started
Drive BD-ROM ATAPI iHES112 3 DL04 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Title #1 was added (16 cell(s), 1:55:48)
Title #3 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #4 has length of 207 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #5 has length of 65 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #6 has length of 224 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #7 has length of 5 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:19:00)
Title #12 was added (16 cell(s), 1:55:48)
Title #14 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #15 was added (14 cell(s), 1:51:44)
Title #17 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #20 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #21/0/4 has length of 3 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #21/0/8 has length of 503 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #23 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #24 was added (14 cell(s), 1:51:42)
Title #26 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 16-16 were removed from title end
Title #27 was added (14 cell(s), 1:54:11)
Title #29 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #30 was added (14 cell(s), 1:54:11)
Title #32 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #33 was added (14 cell(s), 1:54:11)
Title #35 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #36 was added (14 cell(s), 1:51:32)
Title #38 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #39 was added (14 cell(s), 1:51:37)
Title #41 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #42 was added (14 cell(s), 1:54:11)
Title #44 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #45 was added (14 cell(s), 1:54:11)
Title #47 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #48 was added (16 cell(s), 1:55:48)
Title #50 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #51 was added (16 cell(s), 1:55:48)
Title #53 has length of 99 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title 1 in VTS 19 is equal to title 1 and was skipped
Title 1 in VTS 13 is equal to title 1 and was skipped
This gives me several titles:
Tried to process first Title (should only be 1 main title, and a few video special/extras):
Saving 1 titles into directory L:/Videos/_Country Music Disc 2_C5CC
AV synchronization issues were found in file 'L:/Videos/_Country Music Disc 2_C5CC/title.mkv' (title #1)
AV sync issue in stream 1,2,3 at 1:52:46.048 with duration of 78.033ms : audio gap - 2.438 missing frame(s)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_19_1.VOB' at offset '88950784'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '88950784'
Failed to save title 0 to file L:/Videos/_Country Music Disc 2_C5CC/title.mkv
Encountered 32 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Thanks.
Re: Country Music - A Film by Ken Burns (tt9708550)
Post by Woodstock » Sat Nov 23, 2019 8:24 pm
There is a topic on the BD version of this disk here: viewtopic.php?f=8&t=20487&p=78767
You do need to find which is the REAL file with Lionsgate titles, because some of them point to invalid areas of the disk, causing errors.
