American Beauty DVD Region 1
LesSr79
Post by LesSr79 »
Without AnyDVD:
Debug log started at Thu Oct 07 02:28:03 2010 , written by MakeMKV v1.6.0 win(x64-release)
001005:0000 MakeMKV v1.6.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Les Sr/MakeMKV_log.txt
001003:0020 DEBUG: Code 134219780 at ~q#Mu\Z-6gLooXxPn:121261957
001003:0020 DEBUG: Code 0 at ~q#Mu\Z-6gLooXxPn:121263774
003031:0000 Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
003028:0000 Title #0 was added (30 cell(s), 2:01:20)
003025:0000 Title #1 has length of 1312 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
003025:0000 Title #2 has length of 181 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
003025:0000 Title #3 has length of 71 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
003025:0000 Title #4 has length of 3677 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
003025:0000 Title #5 has length of 24 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
003025:0000 Title #6 has length of 34 seconds which is less than minimum title length of 6780 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/Video/AMERICAN_BEAUTY
001003:0020 DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213130490
001003:0020 DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213129639
001003:0020 DEBUG: Code 0 at }{8{aR.=caXQCH>Dnff:29394183
001003:0020 DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29394160
001003:0020 DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29395195
005003:0000 Failed to save title 0 to file D:/Video/AMERICAN_BEAUTY/title00.mkv
005004:0080 0 titles saved, 1 failed
With AnyDVD:
Debug log started at Thu Oct 07 02:33:53 2010 , written by MakeMKV v1.6.0 win(x64-release)
I ran it with AnyDVD because of the RPC Error... Same result!
setarip_old
Re: American Beauty DVD Region 1
Post by setarip_old »
Hi!
The list of titles and times reflects a total time of more than 3 hours. Is this an original, commercial DVD or something else?
1) The usual default minimum title length is 120 seconds (2 minutes). Why is yours set to 6,780 seconds (1 hour and 53 minutes)?
2) What is the nature of Title 4 (1 hour 1 minute and 17 seconds) that was skipped?
3) What version number of MakeMKV are you using?
4) Have you successfully used any version of MakeMKV to create .MKVs from DVDs?
LesSr79
Post by LesSr79 »
Hi setarip_old,
This is a Region 1 Retail DVD
I didn't change those settings but I am using MakeMKV with Auto Rip n Compress... Suppose that is why such a long minmum duration, to be sure to select only the main feature
This may very well be the title I "should" be ripping from the disk
I am using version 1.6.0
I have been using MakeMKV as a stand alon application for a few months for both DVD and Blu-ray.
Also, I have reverted back to 1.5.8 and the few discs I was having problems with have been ripped successfully save for Bruce Almighty which I believe is a physical problem with the media.
Thanks for the insight though, I guess I should have actually read the log before posting it!
LesSr79
Post by LesSr79 »
After actually reading the log I see that Title #0 is the main feature and was recognised by MakeMKV and that there was a read failure later on while attempting to actually rip the title. I have successfully ripped this disk with MakeMKV 1.5.8!
Post by mike admin »
Confirmed problem, will be corrected in a next version.
