[Possible Bug] Audio extract wrong CRC
overdrive
Post by overdrive » Fri Nov 22, 2019 5:45 pm
Hi, folks.
I am doing backup of varios BD, and I am testing various methods.
1. MakeMkv.
2. Mkvmerge by append m2ts
3. DG_Demux
4. CMD, copy function.
When mpls is formed by less o equal to 2 m2ts files, I dont detect mismatching on CRC audio files, in this case DTS-HD MA. However, when playlist consists almost 3 m2ts files, CRC get with Makemkv is different.
I get structure playlist using eac3to, get this (Omitted playlist without conflict):
5) 00001.mpls, 00074.m2ts+00000.m2ts+00002.m2ts, 0:23:02     60
   - h264/AVC, 1080p24 /1.001 (16:9)
   - DTS Master Audio, Spanish, stereo, 48kHz
   - DTS Master Audio, Japanese, stereo, 48kHz
7) 00000.mpls, 00074.m2ts+00000.m2ts+00001.m2ts, 0:22:57         60 TV
Results:
  • With MakeMkv. DTS-HD MA spanish audio (no core) for 00001.mpls of CRC is E7392CC0, and for 00000.mpls is E5C96A15.
  • With MKVmerge by JSON files (00001.mpls and 00000.mpls). DTS-HD MA spanish audio (no core) for 00001.mpls of CRC is 933A8252, and for 00000.mpls is 02BD16E7.
  • With DG_Demux. DTS-HD MA spanish audio (no core) for 00001.mpls of CRC is 933A8252, and for 00000.mpls is 02BD16E7.
  • With CMD using command like "copy /b 00074.m2ts+00000.m2ts+00001.m2ts 60_TV.m2ts". DTS-HD MA spanish audio (no core) for 00001.mpls of CRC is 933A8252, and for 00000.mpls is 02BD16E7.
Bluray folder for testing here
Thanks in advance.
Re: [Possible Bug] Audio extract wrong CRC
Post by mike admin » Fri Nov 22, 2019 9:44 pm
Please enable "show AV sync issues" in preferences and see what MakeMKV does with your audio stream on join points.
overdrive
Post by overdrive » Sat Nov 23, 2019 2:10 am
Log of only conflicts files:
MakeMKV v1.14.5 win(x64-release) comenzado
Abriendo archivos del disco duro en E:/Utorrent/Anime/[BDMV] Dragon Ball Super [Box 5] [SelectaVision] [2 discos] [Con censura] [054-065]/Disco 02
No se encuentra el directorio AACS, asumiendo disco sin encriptación
Se agregó el archivo 00000.mpls como título #0
Se agregó el archivo 00001.mpls como título #1
Se agregó el archivo 00002.mpls como título #2
El título 00003.mpls(1) es idéntico al título 00001.mpls y fue ignorado
Se agregó el archivo 00003.mpls(3) como título #3
Se agregó el archivo 00003.mpls(5) como título #4
Se agregó el archivo 00003.mpls(7) como título #5
Se agregó el archivo 00003.mpls(9) como título #6
Se agregó el archivo 00003.mpls(11) como título #7
El título 00004.mpls es idéntico al título 00003.mpls(3) y fue ignorado
Se agregó el archivo 00005.mpls como título #8
El título 00006.mpls es idéntico al título 00003.mpls(5) y fue ignorado
El título 00008.mpls(1) es idéntico al título 00000.mpls y fue ignorado
El título 00008.mpls(3) es idéntico al título 00002.mpls y fue ignorado
El título 00008.mpls(5) es idéntico al título 00005.mpls y fue ignorado
Se agregó el archivo 00008.mpls(7) como título #9
Se agregó el archivo 00008.mpls(9) como título #10
Se agregó el archivo 00008.mpls(11) como título #11
El título 00011.mpls es idéntico al título 00008.mpls(7) y fue ignorado
El título 00012.mpls es idéntico al título 00003.mpls(7) y fue ignorado
El título 00013.mpls es idéntico al título 00008.mpls(9) y fue ignorado
El título 00014.mpls es idéntico al título 00003.mpls(9) y fue ignorado
El título 00015.mpls es idéntico al título 00008.mpls(11) y fue ignorado
El título 00016.mpls es idéntico al título 00003.mpls(11) y fue ignorado
El título #00007.m2ts tiene una duración de 10 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00008.m2ts tiene una duración de 11 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00009.m2ts tiene una duración de 15 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00010.m2ts tiene una duración de 83 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00014.m2ts tiene una duración de 0 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00021.m2ts tiene una duración de 58 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00022.m2ts tiene una duración de 58 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00023.m2ts tiene una duración de 84 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
El título #00024.m2ts tiene una duración de 84 segundos, que es menor que el mínimo de 120 segundos y fue ignorado
Operación completada con éxito
Guardando 2 títulos en el directorio C:/Users/Isra/Desktop/Nueva carpeta
AV synchronization issues were found in file 'C:/Users/Isra/Desktop/Nueva carpeta/title_t00.mkv' (title #1)
AV sync issue in stream 1,2 at 0:01:23.333 with duration of 5.416ms : encountered overlapping frame, audio skew is +5.416ms
AV sync issue in stream 1,2 at 0:14:42.506 with duration of 5.291ms : encountered overlapping frame, audio skew is +10.708ms
AV sync issue in stream 1,2 at 0:14:42.517 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.041ms
La pista de subtítulos forzados #4 resulta estar vacía y se eliminó en el archivo de destino
La pista de subtítulos forzados #6 resulta estar vacía y se eliminó en el archivo de destino
AV synchronization issues were found in file 'C:/Users/Isra/Desktop/Nueva carpeta/title_t01.mkv' (title #2)
2 títulos guardados
overdrive
Post by overdrive » Sat Nov 23, 2019 10:49 am
In where says: "1 frame(s) dropped to reduce audio skew to +0.041ms". For DTS frame duration is 10.666667 ms, maybe is for that?
