Dora and the Lost City of Gold
Sush1988
Has anyone facing issue with Ripping Dora and the Lost City of Gold? Makemkv throws out error that its unable to decrypt.
Grauhaar
Re: Dora and the Lost City of Gold
Please provide a Debug Log (see my signature)
Is MKB_vxx_xxxxx.tgz file for this title in your "C:/Users/xxxxx/.MakeMKV" folder?
What is the AACS Version? You can see it if the disc is deteced by MakeMKV over the spinning disc icon under "Protection AACS vxx"
Good Luck
Sush1988
HI,
Makemkv didnt save any files and I remember that Makemkv was complaining about encryption that it is not aware of.
Grauhaar
If you not provide more detailed information, it is not possible to help.
Good Luck
MustangChris04
AACS v72
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/...
Saved AACS dump file as C:\Users\chris/.MakeMKV/MKB_v72_Dora_and_the_Lost_City_of_Gold_324C.tgz
Did you click on the link provided, or otherwise send the MKB_v72_Dora_and_the_Lost_City_of_Gold_324C.tgz file to svq@makemkv.com?
AACS v72 came out after 1.14.5 was released, and decrypting it right now requires an update that MakeMKV can normally download on start-up. There should be information about whether or not that update is being loaded in the log window, after you start opening the disk.
