Dora and the Lost City of Gold
Sush1988
Post by Sush1988 »
Has anyone facing issue with Ripping Dora and the Lost City of Gold? Makemkv throws out error that its unable to decrypt.
Grauhaar
Re: Dora and the Lost City of Gold
Post by Grauhaar »
Please provide a Debug Log (see my signature)
Is MKB_vxx_xxxxx.tgz file for this title in your "C:/Users/xxxxx/.MakeMKV" folder?
What is the AACS Version? You can see it if the disc is deteced by MakeMKV over the spinning disc icon under "Protection AACS vxx"
Good Luck :)
Sush1988
Post by Sush1988 »
HI,
Makemkv didnt save any files and I remember that Makemkv was complaining about encryption that it is not aware of.
Grauhaar
Post by Grauhaar »
If you not provide more detailed information, it is not possible to help.
Good Luck :)
MustangChris04
Post by MustangChris04 »
AACS v72
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/...
Saved AACS dump file as C:\Users\chris/.MakeMKV/MKB_v72_Dora_and_the_Lost_City_of_Gold_324C.tgz
Did you click on the link provided, or otherwise send the MKB_v72_Dora_and_the_Lost_City_of_Gold_324C.tgz file to svq@makemkv.com?
AACS v72 came out after 1.14.5 was released, and decrypting it right now requires an update that MakeMKV can normally download on start-up. There should be information about whether or not that update is being loaded in the log window, after you start opening the disk.
