Enable LibreDrive
bigozbear
Re: Enable LibreDrive
took a photo of the model details on its base... easier than describing it
I'm not sure what actual manufacturer/model drive is inside that Buffalo enclosure.bigozbear wrote: Tue Nov 19, 2019 1:41 pm took a photo of the model details on its base... easier than describing it
However, from your previous post:
OS device name: /dev/rdisk9
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN10
Serial number: KZ8H92J1011
Firmware date: 2117-05-30 17:24
Bus encryption flags: 1F
Highest AACS version: 68
Since the drive platform is MT1959, you could try flashing the BU40N Buffalo BU10 firmware to the drive using the modified ASUS flasher. By using this firmware, your drive will be identified as a BUFFALO BRUHD-PU3-BK "Official" UHD drive with libredrive enabled.
Please let us know if this works for you.
Cheers.
bigozbear
Thanks for the tip
But, what do you mean by “flashing?”
...sorry, not THAT tech savvy
To enable libredrive (and UHD reading) you need to change the drive's firmware. This is done by flashing a different firmware to the drives EEPROM.bigozbear wrote: Thu Nov 21, 2019 12:06 am Thanks for the tip
st4evr
Read the forum stickies/guides. They are there to assist with these common questions.bigozbear wrote: Thu Nov 21, 2019 12:06 am Thanks for the tip
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
