Playing MKV files on phone
Amirax
Has anyone met the same problem as me...I can't open a converted file on my phone, but usually, it worked pretty fine. Were there any updates lately?
Re: Playing MKV files on phone
Lots of unknowns here.
Does your phone play MKV files? Apple phones won't, unless you use a third-party app. Android running 6 and later can play MKVs with the built-in viewer, but there are problems with audio sync... so a third-party app is usually needed.
Are you processing the MKV files to MP4?
