FATAL ERROR - Iron Man 2 & 3 UHD
slide
#1 Post by slide » Wed Nov 13, 2019 8:42 pm
//UPDATE 2019-11-19//
The Iron Man 1-3 BluRay + UHD Box I bought arrived sealed. The disks were clean and shiny under every angle. YET THEY WERE DEFECTIVE!
I asked a friend if I could borrow his disks and the WH14NS40 as well as the BW-16D1HT ripped them without an issue!
So the lesson here is that even if the disks is brand new, arrived sealed and looks flawless, it can still be broken!
//END
I got a brand new WH14NS40.
I can rip the Iron Man 1 UHD and the Spider-Man Far from Home UHD just fine with MK "HL-DT-ST-BD-RE_WH16NS60-1.01-NM00100-211711202000" on my
But MakeMKV 1.14.5 encounters a 'FATAL ERROR' while ripping the Iron Man 2 and Iron Man 3 UHD.
Debug log attached.
also tried with the following FW's, always the same fatal error.
DE_LG WH16NS60_1.00.bin
DE_flash_HL-DT-ST_BD-RE_WH14NS40_1.02_NS50.bin
MK HL-DT-ST-BD-RE_WH16NS40-NS50-1.03-NM00600-211711211653
MakeMKV_log_IronMan2.txt
(811.48 KiB) Downloaded 673 times
MakeMKV_log.txt
(1.09 MiB) Downloaded 639 times
slide
Re: FATAL ERROR - Iron Man 2 & 3 UHD
#2 Post by slide » Thu Nov 14, 2019 5:03 pm
Little update. I could just rip the Spider-Man Far from Home UHD disk without any issue at all. No clue whats going on with those Iron Man 2 and Iron Man 3 UHD disks crashing MakeMKV.
slide
#3 Post by slide » Tue Nov 19, 2019 6:33 am
The Iron Man 1-3 BluRay + UHD Boxset I bought arrived sealed. The disks were clean and shiny under every angle. YET THEY WERE DEFECTIVE!
I asked a friend if I could borrow his disks and the WH14NS40 ripped them without an issue!
So the lesson here is that even if the disks is brand new, arrived sealed and looks flawless, it can still be broken! :x :x :x
