No audio from DVD rip
Blondie
Post by Blondie »
Purchased Kurios Cirque du soleil at the show this week and wished to make a backup.
Running v1.14.5 on Mac 10.11.6 (el capitan).
Have gone back to 2015 on forums and can find no similar problem. Help pls.
Re: No audio from DVD rip
What are you using to play the MKV?
As a DVD, it should have AC3 as one of the audio tracks, for compatibility.
Blondie
Post by Blondie »
Woodstock wrote: Sat Nov 16, 2019 3:23 pm What are you using to play the MKV?...
I used VLC but I checked the media info and there definitely was no audio track.
However I'm sorted now, thanks. When I went through the online help, I found a screen shot of the Windows beta. It displayed that titles can be expanded to drill down to select vid, audio & subs - something I'd never noticed before! Feel like such a dope. I'd always used the auto settings without issue.
So I've run it again and got the complete file. Thanks to you and the developers.
One thing it might be - what language did it have for the audio?
If you have set a preferred language in Preferences->Language, MakeMKV will not automatically select tracks for any other language.
Blondie
Post by Blondie »
Woodstock wrote: Sat Nov 16, 2019 10:49 pm One thing it might be - what language did it have for the audio?
I've never fiddled with the default settings, hence they are:
Interface language: Auto
Preferred language: English
{Aside: The Kurios DVD had English and French audio settings, so in theory, it should have selected the audio. The DVD is not a run-of-the-mill so I cannot fault the program. For instance, it has a subtitle option yet when we selected it on the player, it returned an error saying "not permitted". Out of curiosity, I extracted it to take a look, and it was just garbage characters that ran for about 20 minutes. So I've left it out from the encode.}
Good to know that extra info you've provided though; thank you.
