John Wick: Chapter 3 - Parabellum
kevonator
Re: John Wick: Chapter 3 - Parabellum
According to process monitor .0429 mpls is correct for netflix. This is the first time I've used process monitor. I cannot confirm it's correct yet. Anybody else who knows the correct playlist for netflix? please chime in.
alephbaker
just want to confirm for other users, using oddeyeball's method I can corroborate ChrisCaPWN is correct on the segment map for some non-retail discs. the trick being that, as far as I know, rbx and nfx both still supplement their catalogs by buying retail copies. this particular disc does not look like a rental.
Title information
Name: John Wick 3: Parabellum
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t365.mkv
rbtf70
Want to confirm that my USA Retail version is correct with the earlier posted file:
Source file name: 00957.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
Ripped the Blu-Ray disk and played the copy on the same screen next to the DVD. Matches perfectly. 100%. Thanks for the assistance. This forum is the best!
Duration: 2:10:45
Chapters count: 16
Segment count: 19
SilentKnight09
I can verify the following to be correct for the U.S. retail version (4k/Bluray combo)
Source file name: 00444.mpls
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t197.mkv
Currently using Windows10 - Java version 8 update 231.
I have noticed there are many versions of this disc many that display the correct segment map under a different File name (t197). This could be a java version related issue or just different disc versions. I would suggest updating java first and if you cant find the exact file name you will have to match by the segment map.
Hope this helps.
Hope this helps.
Lanthade
I can confirm it was correct for the disc I got.kevonator wrote: Wed Oct 09, 2019 7:50 pm According to process monitor .0429 mpls is correct for netflix. This is the first time I've used process monitor. I cannot confirm it's correct yet. Anybody else who knows the correct playlist for netflix? please chime in.
KiltedShane
- Contact:
I have a non-rental Netflix disc. According to Process Monitor this is the source and segment map.
Name: John Wick 3: Parabellum (English)
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
6:20:28.1552163 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00510.m2ts SUCCESS
6:20:29.6250342 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00511.m2ts SUCCESS
6:20:31.3723990 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00502.m2ts SUCCESS
6:20:32.9003049 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00505.m2ts SUCCESS
6:21:34.9833903 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00512.m2ts SUCCESS
6:21:36.0805842 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00501.m2ts SUCCESS
6:21:37.8188035 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00519.m2ts SUCCESS
6:21:38.9949787 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00516.m2ts SUCCESS
6:22:52.6964980 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00508.m2ts SUCCESS
6:22:54.1883468 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00514.m2ts SUCCESS
6:22:55.8565943 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00507.m2ts SUCCESS
6:23:59.8016667 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00515.m2ts SUCCESS
6:24:03.9659571 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00518.m2ts SUCCESS
6:24:05.5542138 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00503.m2ts SUCCESS
6:24:07.1680590 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00509.m2ts SUCCESS
6:25:15.2433734 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00504.m2ts SUCCESS
6:25:16.6718962 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00520.m2ts SUCCESS
6:25:18.4605802 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00517.m2ts SUCCESS
6:28:15.8826476 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00506.m2ts SUCCESS
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Geneo
What is the conclusion for a Walmart Retail Blue-Ray
Geneo
In the running are:
- John Wick 3- Parabellum_t134-298.mpls
John Wick 3- Parabellum_t167-429.mpls
John Wick 3- Parabellum_t180-444.mpls
John Wick 3- Parabellum_t380-965.mpls
John Wick 3- Parabellum_t385-957.mpls
Geneo
Geneo wrote: Sat Nov 16, 2019 9:50 pm In the running are:
John Wick 3- Parabellum_t167-429.mpls Not on my disc
John Wick 3- Parabellum_t180-444.mpls On My disc this is t163-444 and does not play correctly
John Wick 3- Parabellum_t380-965.mpls Not on my disc
Geneo
This ended up being the one that worked for me.
US Retail Target
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
File name: John Wick 3- Parabellum_t392.mkv
US Retail Target
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Geneo
I found the 444.mpls would have a screen switch around the scene where John is sitting with Sofia on the couches. But that was with the Bluray/digital combo. Maybe not the same.SilentKnight09 wrote: Mon Nov 04, 2019 5:16 am I can verify the following to be correct for the U.S. retail version (4k/Bluray combo)
Hope this helps.
Mr_Orange
I just bought the Region B version from Amazon Aus and there did not appear to be any obfuscation at all. Using MakeMKV 1.14.7, only three tracks were listed and two of them were far too small to be the main feature.
It seems as though everyone else in this thread has had some sort of obfuscation to deal with. Have I messed something up?
stonkr
My UK version is playlist 00696 with segment map 505,514,512,502,517,501,506,508,509,503,518,507,510,519,520,511,504,515,516.
I had to go the long way round with this one and piece together the segments in the correct order.
IrishPrince
US Netflix source..... Confirmed it works...
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
spoolinchaos
Created an account to also confirm, using the Process Monitor, I got the following with a Netflix Blu-ray disc.
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
File name: John Wick 3: Parabellum.mkv
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
