I'm using MakeMKV v1.14.5 on Windows 7 and I've attempted this disc almost a dozen times now. I've power cycled the blu-ray player and restarted MakeMKV, nothing seems to work. I've browsed around the forums and haven't seen this specific issue talked about. The Blu-Ray player I'm using is an LG BP50NB40 flashed with BP60NB10 firmware.
Below is a copy of the output makeMKV spits out
Any help and advice would be greatly appreciatedUsing direct disc access mode
Using LibreDrive mode (v05 id=4ACF8047C3AC)
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/AACS/Content000.cer' at offset '0'
Failed to load content hash table, unable to verify integrity of M2TS files.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '82575360'
Error 'Internal error - Operation was cancelled (122)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '82601984'
Error 'Internal error - Operation was cancelled (122)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '82575360'
Error 'Internal error - Operation was cancelled (122)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '82612224'
Error 'Internal error - Operation was cancelled (122)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '83755008'
Error 'Internal error - Operation was cancelled (122)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00' at offset '83789824'
Error 'Internal error - Operation was cancelled (122)' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Title #00002.mpls was skipped
Error 'Internal error - Operation was cancelled (122)' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
Title #00009.mpls was skipped
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Internal error - Operation was cancelled (122)' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '0'
Title #00033.mpls was skipped
Title #00020.mpls was skipped
Title #00035.mpls was skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts was skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts was skipped
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts was skipped
Title #00031.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
