Grencola
Post by Grencola »
yusesope, I've tried a few of your test files using YusesoPlayer on the Amazon Fire TV Stick 4k and I get the same result: working hd-audio and dolby vision flag on the tv but just black video. However the single layer dvhe 5.06 mp4 sample files from LG play perfectly in dolby vision, both with your player and in mx player. getting close :)
baker99
Post by baker99 »
Following the single layer DV guide with DTS audio is working great but the file sizes seem a lot smaller than the original m2ts files, is some compression going on or is it just due to less streams being in the output? Wondering if I have something set wrong in DVDFab, although it does say it's just copying.
agentreza
Post by agentreza »
Hello peepz! Need some pointers - I have a dual layer dv movie remux in mp4, would like to convert that to a single layer mp4 with DVDFab to test on the new shield TV.
baker99 wrote: Thu Nov 14, 2019 8:52 pm Following the single layer DV guide with DTS audio is working great but the file sizes seem a lot smaller than the original m2ts files, is some compression going on or is it just due to less streams being in the output? Wondering if I have something set wrong in DVDFab, although it does say it's just copying.
the process is lossless.
agentreza wrote: Fri Nov 15, 2019 2:09 am Hello peepz! Need some pointers - I have a dual layer dv movie remux in mp4, would like to convert that to a single layer mp4 with DVDFab to test on the new shield TV.
I don't think you can do that. You need to rip from the ISO/folder structure.
superfans124
Post by superfans124 »
RESET_9999 wrote: Fri Nov 15, 2019 3:05 am
quick question, how do you deselect audio track in DVDfab? I'm demoing the software, I found the single-layer/dual-layer options in settings, but for the life of me, I don't see any option to not select any audio stream to create just the video stream for mp4box. god I feel dumb...
Grencola
Post by Grencola »
you could try Dolby's mp4demuxer, and then use tsMuxer to create an m2ts file from that to feed dvdfab.
https://github.com/DolbyLaboratories/dl ... /master?q=
superfans124 wrote: Fri Nov 15, 2019 4:04 am
With DVDFAB, you cant. You remove the first audio when you add the lossless audio with mp4box:
mp4box.exe -add X:\dvdfab-single-layer.mp4#1 -add X:\lpcm.mov#audio:lang=en-EN -tmp X:\ -brand mp42isom -ab dby1 -no-iod X:\dolbyvision-remux.mp4
baker99
Post by baker99 »
Thank you :)
yusesope
Post by yusesope »
Before continuing on the path taken, I would like to test a new idea.
Those interested can download the new app and the new server HERE and the new sample file HERE.
I recommend limiting yourself to the file I uploaded (it's special :D ). You will find in the archive a TrueHD/ATMOS track and a DV dvhe.05 track. Both must be loaded into the server in the usual way.
The IP address of the server remains 192.168.1.130 and to change it use the previous instructions.
If the idea proves to be successful, I will explain to you how to rework the files you own.
As always I thank you for your feedback.
baker99
Post by baker99 »
yusesope wrote: Fri Nov 15, 2019 7:18 pm Before continuing on the path taken, I would like to test a new idea.
It's working with Atmos and Dolby Vision, I had to select Atmos on my AV receiver though, on previous demos it automatically triggered Atmos but this may just be an issue with my setup. Using a Shield TV Pro 2019, LGC6 and Denon X2500
justinadams
Post by justinadams »
Can confirm this split method (sample file) does work no problem. Vizio Quantum X, Denon AVR-S750H, and shield tv pro 2019.
Grencola
Post by Grencola »
justinadams wrote: Sat Nov 16, 2019 12:34 am Can confirm this split method (sample file) does work no problem. Vizio Quantum X, Denon AVR-S750H, and shield tv pro 2019.
Lovin my Quantum X! How you liking it?
justinadams
Grencola wrote: Sat Nov 16, 2019 5:38 am
It's pretty freaking fantastic. a few minor things here and there, but nothing game breaking(aside from vizio smartcast)
Grencola
Post by Grencola »
justinadams wrote: Sat Nov 16, 2019 6:01 am It's pretty freaking fantastic. a few minor things here and there, but nothing game breaking(aside from vizio smartcast)
Agreed 8) And just got the hdr10+ update, Amazon Prime content looks amazing now.
Grencola
Post by Grencola »
same results on the AFTV Stick 4k, flags dolby vision but black screen. it also can't do lossless atmos, just dd+ or lpcm 7.1, but cool that it works on the shield!
