Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Locked
mgadbois
Re: Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Post by mgadbois »
Thanks for the feedback. I appreciate the response.
DVD Maniac
Post by DVD Maniac »
Thanks for the post. Have never used one of these because they are not available in UK, well only at extortionate prices on Amazon. Can I ask what you pay in US?
mgadbois
Post by mgadbois »
$104.
markymark
Post by markymark »
@tragic bleak,
Thanks so much for your guide and updating it. Following your suggestion and this guide.
I bought the LG WH16NS60, it came with fw 1.02. I had it installed and ripping in one of my UHD Blu rays in 15 minutes.
Thanks again for your time and effort in creating this guide.
Mark.
mgadbois
Post by mgadbois »
I must be doing something wrong because it takes me 40 or so minutes to RIP a 4K UHD disk now. I am curious how you got the speed so fast.
mgadbois wrote: Fri Nov 15, 2019 2:29 am I must be doing something wrong because it takes me 40 or so minutes to RIP a 4K UHD disk now. I am curious how you got the speed so fast.
40 mins is normal for a 66 GB disk 100GB discs 60 mins
i think he means he was setup and flashed in 15 mins
mgadbois
Post by mgadbois »
Thanks for the information. I didn't know those numbers before.
markymark
Post by markymark »
Yes Billy is correct. 15 min to install and flash the drive. I ripped a UHD disk successfully. It did take around 40 minutes.
omk1980
Post by omk1980 »
So i have a LG WH16NS60. I flashed it in august 2019 to v1.01 that is libre drive enabled. Should i flash to 1.02mk? i've been getting a lot of disc read errors as of late and not sure if upgrading firmware will allow for a better ripping experience.
omk1980 wrote: Sat Dec 14, 2019 4:43 am So i have a LG WH16NS60. I flashed it in august 2019 to v1.01 that is libre drive enabled. Should i flash to 1.02mk? i've been getting a lot of disc read errors as of late and not sure if upgrading firmware will allow for a better ripping experience.
not going to help anything a bad disk is a bad disk a bad drive is a bad drive what you have i dont know
omk1980
Post by omk1980 »
Billycar11 wrote: Sat Dec 14, 2019 4:51 am
Hoping it's a bad disk. Can't get fury but was able to get Spider-Man 2002 today on same drive.
My question is does 1.02mk offer any advantages to my 1.01? Uhd playback isn't too important to me.
omk1980 wrote: Sat Dec 14, 2019 5:02 am
i know of no advantages lg does not post patch notes or even the firmware itself
omk1980
Post by omk1980 »
Billycar11 wrote: Sat Dec 14, 2019 5:07 am
Thank you. I'll leave it alone then.
BBreeziN
Post by BBreeziN »
Question for the experts here, I just bought a WH16NS60 that was manufactured on 20191029. It came with 1.02 firmware. I flashed the 1.02 MK firmware according to these instructions. At 100%, I got a message that said "Update Failed The drive may will be emergency mode This mode is allowed only F/W flash Sense 00/00/00".
I rebooted, and my drive appears to be working fine, and MakeMKV shows it as LibreDrive enabled. Am I good to go? Was this error harmless? Thanks for the all the work collecting this information in one place and the help!
BBreeziN wrote: Thu Jan 02, 2020 8:46 pm Question for the experts here, I just bought a WH16NS60 that was manufactured on 20191029. It came with 1.02 firmware. I flashed the 1.02 MK firmware according to these instructions. At 100%, I got a message that said "Update Failed The drive may will be emergency mode This mode is allowed only F/W flash Sense 00/00/00".
Harmless some sata controllers are weird same with the USB to sata converters
Locked
