Six Swedes In Paradise - MakeMKV Fails To Rip
leethompson
Post by leethompson »
MakeMKV v.1.14.5 (x64)
OS: Windows 10 Enterprise (x64) (1903)
MakeMKV failed to save the main title of "Six Swedes In Paradise" (Full Moon Features https://www.fullmoondirect.com/Six-Swed ... _1381.html) which is a very simply authored DVD (while not a DVD-R it isn't copy protected, at all, and authored with Adobe Encore DVD).
It takes an usually log time for the initial scan with a lot of "complex multiplex encountered" messages.
When attempting to save main title (Title #3) to HDD, no errors appear in the MakeMKV console it just creates a 0 byte file and makes no progress. The elapsed time values simply increase.
I tried the disc in two different drives (the PLEXTOR and the ASUS).
(I ended up just using the old DVD Decrypter.)
Log:
Debug log started at Fri Nov 15 01:29:21 2019 , written by MakeMKV v1.14.5 win(x64-release)
001005:0000 MakeMKV v1.14.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\REDACTED/MakeMKV_log.txt
No  SDF v063: PLDS_DVD+-RW_DU-8A5LH_6D11_CN0YYCRWPLC0072O7NLIA05
SDF id v063: PLDS_DVD+-RW_DU-8A5LH_6D11_CN0YYCRWPLC0072O7NLIA05
No  SDF v063: PLEXTOR_DVDR___PX-L890UE_1.04_3744524024_266103500484
SDF id v063: PLEXTOR_DVDR___PX-L890UE_1.04_3744524024_266103500484
No  SDF v063: ASUS_BW-16D1X-U_E111_RLDL050317WL
SDF id v063: ASUS_BW-16D1X-U_E111_RLDL050317WL
No  SDF v063: HL-DT-ST_BD-RE_BP60NB10_1.00_211711221432_SIM00J1FD2741
SDF id v063: HL-DT-ST_BD-RE_BP60NB10_1.00_211711221432_SIM00J1FD2741
No auto SDF v063: PLEXTOR_DVDR___PX-L890UE_1.04_3744524024_266103500484
DEBUG: Code 0 at !BYd\|M  dT`ziq.g:29395540
DEBUG: Code 0 at Y{8*?>3AcVD%BwC>n:121261773
DEBUG: Code 0 at Y{8*?>3AcVD%BwC>n:29393792
003025:0000 Title #1 has length of 8 seconds which is less than minimum title length of 9 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (1 cell(s), 0:00:43)
Title skip vts=1 pgcn=1 hash=6AE10B375B47EF72
003019:0000 Cells 18-end were skipped due to cell commands (structure protection?)
003024:1000 Complex multiplex encountered - 17 cells and 10823 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #3 was added (17 cell(s), 1:30:07)
Title skip vts=2 pgcn=1 hash=4E1BCBF8BB60FD36
003024:1000 Complex multiplex encountered - 1 cells and 174 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #4 was added (1 cell(s), 0:01:27)
Title skip vts=3 pgcn=1 hash=924D410BA6662CA3
003024:1000 Complex multiplex encountered - 1 cells and 102 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #5 was added (1 cell(s), 0:00:51)
Title skip vts=4 pgcn=1 hash=34389202308170C0
003024:1000 Complex multiplex encountered - 1 cells and 135 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #6 was added (1 cell(s), 0:01:07)
Title skip vts=5 pgcn=1 hash=03A21B9DA9DD0F6B
003024:1000 Complex multiplex encountered - 1 cells and 158 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #7 was added (1 cell(s), 0:01:19)
Title skip vts=6 pgcn=1 hash=9CF5B4F0539BE6FD
003028:0000 Title #8 was added (1 cell(s), 0:00:46)
Title skip vts=7 pgcn=1 hash=7E5B1C97B9D279C7
003024:1000 Complex multiplex encountered - 1 cells and 128 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #9 was added (1 cell(s), 0:01:04)
Title skip vts=8 pgcn=1 hash=C4B4FC7282D899FC
003024:1000 Complex multiplex encountered - 1 cells and 159 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #10 was added (1 cell(s), 0:01:19)
Title skip vts=9 pgcn=1 hash=96ADE7242C207FA1
003024:1000 Complex multiplex encountered - 1 cells and 9727 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #11 was added (1 cell(s), 1:21:03)
Title skip vts=11 pgcn=1 hash=CEF888E43CF45B5D
001003:0020 DEBUG: Code 3221225664 at #u3=B4g@!D|[(=@{:121266649
005014:0000 Saving 1 titles into directory E:/Media/Processing/Discs/Video/Temp
001003:0020 DEBUG: Code 0 at DoTRs5pl`B``y*,hj:121262026
Grauhaar
Re: Six Swedes In Paradise - MakeMKV Fails To Rip
Post by Grauhaar »
If yu have the VTS VOB files (decryted) you can use "MakeToolNIX GUI" to create an mkv file. Add and append the related VTS VOB file(s) (up to 9 VOB files, each are 1GB) with append (!!!) (add the first file, than click right on the "source file" VOB, and append the other VOB files). Do not use the "add source files" button option for the other files, because this merges all tracks into the mkv file and you have n video, n audio and so on tracks. If the append option is used, you have one video and the related audio and subtitle tracks only once. Select the tracks needed and mux it. Maybe it works.
Good Luck :)
Suggestion: Visit https://makemkv.com/download/old/ and pull down an older copy of MakeMKV, such as 1.12.3. Install it in a DIFFERENT directory than your current copy; this will prevent it from trying to wipe out the current install.
Start the old version, and try ripping the DVD again.
I've been working with Mike on an issue where some DVDs that rip with older versions don't work with 1.14.5, and if that's the case here, Mike will want more information from you.
leethompson
1.12.3 has the exact same issue.
(I've long finished my processing for this DVD, it's now in a nice HEVC mp4 file and the DVD is heading for the shelf.)
Debug log started at Fri Nov 15 06:02:07 2019 , written by MakeMKV v1.12.3 win(x64-release)
001005:0000 MakeMKV v1.12.3 win(x64-release) started
005075:0000 The new version 1.14.5 is available for download at http://www.makemkv.com/download/
001003:0020 DEBUG: Code 0 at [9CTUcW}lT(|/'*^W:121262026
