Renaming Audio & Subtitle Tracks...
swampdaddy
Post by swampdaddy »
I recently learned that I can rename an audio track via MKVToolNix however it takes a while to re-write a 30GB movie for this simple edit. Is there not a way to edit this resource in an easier way? Typically, I just want to name an audio track, changing from "Stereo" to "Commentary". Thoughts? Do you rename any of your tracks?
Thanks,
Robert
Re: Renaming Audio & Subtitle Tracks...
Post by d00zah »
Use the 'Header editor' feature to modify description strings for any track without remuxing.
swampdaddy
Thanks, I'll give that a whirl!
