Title information
Name: The Peanut Butter Falcon
Source file name: 00961.mpls
Duration: 1:36:56
Chapters count: 12
Segment count: 18
Segment map: 511,514,513,504,512,510,503,516,517,508,515,509,500,507,501,502,506,505
File name: The Peanut Butter Falcon_t388.mkv
Steveredrum
Re: The Peanut Butter Falcon
Thanks works for me
hnahorton
Just came here to post this, thanks!
lebelm
Is this redbox version as well?
hvnphoto
I believe Wayflix had posted that Redbox has the same playlist. If you have the same playlist and the segments match then you're good.
ProjectBlu
Just checked a Redbox disc and it did have the same segment map for that playlist.
billbillw
Thanks for posting. The Java obfuscation thing didn't even try to figure out which playlist was correct.
CaptBender
I confirmed the same info on the Netflix version. I haven't watched to confirm it works, but I can't think of a time this has not worked. Thanks!
