The Peanut Butter Falcon
hvnphoto
Post by hvnphoto »
Title information
Name: The Peanut Butter Falcon
Source file name: 00961.mpls
Duration: 1:36:56
Chapters count: 12
Segment count: 18
Segment map: 511,514,513,504,512,510,503,516,517,508,515,509,500,507,501,502,506,505
File name: The Peanut Butter Falcon_t388.mkv
Steveredrum
Re: The Peanut Butter Falcon
Post by Steveredrum »
Thanks works for me :D
hnahorton
Post by hnahorton »
Just came here to post this, thanks!
lebelm
Post by lebelm »
Is this redbox version as well?
hvnphoto
Post by hvnphoto »
lebelm wrote: Wed Nov 13, 2019 1:09 pm Is this redbox version as well?
I believe Wayflix had posted that Redbox has the same playlist. If you have the same playlist and the segments match then you're good.
ProjectBlu
Post by ProjectBlu »
Just checked a Redbox disc and it did have the same segment map for that playlist.
billbillw
Post by billbillw »
Thanks for posting. The Java obfuscation thing didn't even try to figure out which playlist was correct.
CaptBender
Post by CaptBender »
I confirmed the same info on the Netflix version. I haven't watched to confirm it works, but I can't think of a time this has not worked. Thanks!
