Angry Birds 2
Angry Birds 2
Playlists that automatically pop up are 0001, 0436 and 0437. Anyone know which it is?
Re: Angry Birds 2
Most likely 0001.avenger09123 wrote: ↑Wed Nov 13, 2019 2:20 amPlaylists that automatically pop up are 0001, 0436 and 0437. Anyone know which it is?
Re: Angry Birds 2
0001 is a minute shorter than 0436 and 0437. 0436 and 0437 are the same length. I just viewed 0436, and it appears to be the right one from the theater.
Re: Angry Birds 2
Well, there you go!avenger09123 wrote: ↑Wed Nov 13, 2019 3:07 am0001 is a minute shorter than 0436 and 0437. 0436 and 0437 are the same length. I just viewed 0436, and it appears to be the right one from the theater.
Re: Angry Birds 2
How about UHD? There 00001, 00248, 00249, 00252, and 00253. All but 0001 are 1:36:47 in length. 00001 is 1:28:43.
Any ideas on correct mpls?
Re: Angry Birds 2
Try and play index.bdmv. Make note of the playlist file it opens. 99% of the time, this is the correct playlist.
Re: Angry Birds 2
How do you play the index.bdmv?MartyMcNuts wrote: ↑Tue Nov 19, 2019 6:06 amTry and play index.bdmv. Make note of the playlist file it opens. 99% of the time, this is the correct playlist.
Re: Angry Birds 2
Alright I figured out how to play BDMV folder in MPC-HC. However, it is opening "00001.m2ts" which appears to be the one with length 1:28:44. According to IMDB the movie is supposed to be 1:37:00.
Is MPC-HC opening the correct file for sure?
Re: Angry Birds 2
In windows explorer, navigate to the BDMV folder. Open "index.bdmv" in MPC-HC. It should tell you (in the top left corner) which playlist it is opening.
Re: Angry Birds 2
It wouldn't open doing it this way. I was able to open it by going to "Open Directory..." and then selecting the entire BDMV folder. Like I said, it opens 00001.m2ts which does not seem like the correct playlist given the movie duration (1:28:44).MartyMcNuts wrote: ↑Fri Nov 22, 2019 4:01 amIn windows explorer, navigate to the BDMV folder. Open "index.bdmv" in MPC-HC. It should tell you (in the top left corner) which playlist it is opening.
Re: Angry Birds 2
Has the disc been decrypted? I always decrypt the disc to a folder using MakeMKV first. I've never had an issue opening index.bdmv from the decrypted folder.EmKayVe wrote: ↑Fri Nov 22, 2019 6:38 pmIt wouldn't open doing it this way. I was able to open it by going to "Open Directory..." and then selecting the entire BDMV folder. Like I said, it opens 00001.m2ts which does not seem like the correct playlist given the movie duration (1:28:44).MartyMcNuts wrote: ↑Fri Nov 22, 2019 4:01 amIn windows explorer, navigate to the BDMV folder. Open "index.bdmv" in MPC-HC. It should tell you (in the top left corner) which playlist it is opening.
Also, as I mentioned before, it's about 99% accurate. It can occasionally grab the wrong playlist if there are any that are longer in duration than the main movie.
My Toy Story 3 UHD does this. The index.bdmv file was playing a non-english version of the movie which is a couple of minutes longer than the English version.
IDMB shows 97 minutes as the duration for Angry Birds 2, so the index.bdmv must be selecting the wrong playlist in this instance. So it has to be one of the other 4 playlists you mentioned.
Re: Angry Birds 2
I'm trying to figure this out too. Did either of you ever figure out the correct playlist?
Re: Angry Birds 2
Looks like 001 is just the movie, minus the credits.
all the playlist start with 1, then the last 2 have 381 and 382 added. Those files are the end credits. Not sure what's different between them.
Re: Angry Birds 2
For the US 4K from Amazon, 248 worked for me, English audio/subtitles/credits.
Re: Angry Birds 2
The difference is that the actors' names aren't shown during the first part of the credits next to their birds when they are depicted with post-it notes.
