Angry Birds 2
avenger09123
Angry Birds 2
Post by avenger09123 »
Playlists that automatically pop up are 0001, 0436 and 0437. Anyone know which it is?
Re: Angry Birds 2
avenger09123 wrote: Wed Nov 13, 2019 2:20 am Playlists that automatically pop up are 0001, 0436 and 0437. Anyone know which it is?
Most likely 0001.
avenger09123
Re: Angry Birds 2
MartyMcNuts wrote: Wed Nov 13, 2019 2:31 am Most likely 0001.
0001 is a minute shorter than 0436 and 0437. 0436 and 0437 are the same length. I just viewed 0436, and it appears to be the right one from the theater.
Re: Angry Birds 2
avenger09123 wrote: Wed Nov 13, 2019 3:07 am
Well, there you go!
EmKayVe
Re: Angry Birds 2
Post by EmKayVe »
How about UHD? There 00001, 00248, 00249, 00252, and 00253. All but 0001 are 1:36:47 in length. 00001 is 1:28:43.
Any ideas on correct mpls?
Re: Angry Birds 2
EmKayVe wrote: Tue Nov 19, 2019 5:19 am How about UHD? There 00001, 00248, 00249, 00252, and 00253. All but 0001 are 1:36:47 in length. 00001 is 1:28:43.
Try and play index.bdmv. Make note of the playlist file it opens. 99% of the time, this is the correct playlist.
EmKayVe
Re: Angry Birds 2
Post by EmKayVe »
MartyMcNuts wrote: Tue Nov 19, 2019 6:06 am Try and play index.bdmv. Make note of the playlist file it opens. 99% of the time, this is the correct playlist.
How do you play the index.bdmv?
EmKayVe
Re: Angry Birds 2
Post by EmKayVe »
Alright I figured out how to play BDMV folder in MPC-HC. However, it is opening "00001.m2ts" which appears to be the one with length 1:28:44. According to IMDB the movie is supposed to be 1:37:00.
Is MPC-HC opening the correct file for sure?
Re: Angry Birds 2
EmKayVe wrote: Fri Nov 22, 2019 2:07 am Alright I figured out how to play BDMV folder in MPC-HC. However, it is opening "00001.m2ts" which appears to be the one with length 1:28:44. According to IMDB the movie is supposed to be 1:37:00.
In windows explorer, navigate to the BDMV folder. Open "index.bdmv" in MPC-HC. It should tell you (in the top left corner) which playlist it is opening.
EmKayVe
Re: Angry Birds 2
Post by EmKayVe »
MartyMcNuts wrote: Fri Nov 22, 2019 4:01 am In windows explorer, navigate to the BDMV folder. Open "index.bdmv" in MPC-HC. It should tell you (in the top left corner) which playlist it is opening.
It wouldn't open doing it this way. I was able to open it by going to "Open Directory..." and then selecting the entire BDMV folder. Like I said, it opens 00001.m2ts which does not seem like the correct playlist given the movie duration (1:28:44).
Re: Angry Birds 2
EmKayVe wrote: Fri Nov 22, 2019 6:38 pm
Has the disc been decrypted? I always decrypt the disc to a folder using MakeMKV first. I've never had an issue opening index.bdmv from the decrypted folder.
Also, as I mentioned before, it's about 99% accurate. It can occasionally grab the wrong playlist if there are any that are longer in duration than the main movie.
My Toy Story 3 UHD does this. The index.bdmv file was playing a non-english version of the movie which is a couple of minutes longer than the English version.
IDMB shows 97 minutes as the duration for Angry Birds 2, so the index.bdmv must be selecting the wrong playlist in this instance. So it has to be one of the other 4 playlists you mentioned.
jeremybrice
Re: Angry Birds 2
Post by jeremybrice »
I'm trying to figure this out too. Did either of you ever figure out the correct playlist?
Kevinicus
Re: Angry Birds 2
Post by Kevinicus »
Looks like 001 is just the movie, minus the credits.
all the playlist start with 1, then the last 2 have 381 and 382 added. Those files are the end credits. Not sure what's different between them.
pjarvi
Re: Angry Birds 2
Post by pjarvi »
For the US 4K from Amazon, 248 worked for me, English audio/subtitles/credits.
zbigfish
Re: Angry Birds 2
Post by zbigfish »
Kevinicus wrote: Sat Dec 28, 2019 12:45 am Looks like 001 is just the movie, minus the credits.
The difference is that the actors' names aren't shown during the first part of the credits next to their birds when they are depicted with post-it notes.
