I bought the Ironman 1/2/3 boxset which contains the normal BluRay's and the UHD BluRay's//UPDATE 2019-11-19//
The Iron Man 1-3 BluRay + UHD Boxset I bought arrived sealed. The disks were clean and shiny under every angle. YET THEY WERE DEFECTIVE!
I asked a friend if I could borrow his disks and the WH14NS40 as well as the BW-16D1HT ripped them without an issue!
So the lesson here is that even if the disks is brand new, arrived sealed and looks flawless, it can still be broken!
I'm using an Asus BW-16D1HT where I flashed the 3.02 FW following the guide in the forum.
https://www.makemkv.com/forum/viewtopic ... 873#p70308
https://www.youtube.com/watch?v=Yfpf6HoMMis
makeMKV 1.14.5 manages to rip the normal BluRay version just fine!
But on all 3 UHD disks makeMKV throws an error after it copied between 15 to 21 GigaByte of the movie already.
I can reproduce this behavior on another PC where makeMKV was never installed before.
Saving 1 titles into directory D:/extract
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11735463936'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '11735463936'
Failed to save title 0 to file D:/extract/title_t00.mkv
https://imgur.com/NdZ3sOG
https://imgur.com/O7EZ10M
https://imgur.com/FkWEv3j
Could there be something wrong with the FW?
