My Own Private Idaho (Criterion) Disc 2
bigmack3000
Post by bigmack3000 »
Hey,
Disc 2 of this release has a few Audio only extras. They do not show up in the Make MKV scan. Is there a way to get these off of the dvd? Thanks.
Re: My Own Private Idaho (Criterion) Disc 2
Set your minimum title length in preferences to a lower number. MakeMKV will ignore anything shorter than that.
bigmack3000
The Minimum length is already set to 9 seconds. These are lengthy audio interviews.
Grauhaar
Post by Grauhaar »
I think the reason for this is very simple. MakMKV is not designed to select audio only titles. MKV (Video and Audio) versus MKA (Only audio) container.
You must use an other tool to make an decryted back up to get the VTS VOB files (if the audio is stored in VOB (Video Object) files. After this you can "MKVToolNIX GUI" to open the VTS VOB file(s).
Good Luck :)
bigmack3000
Do you have any recommendations for what to use?
bigmack3000
If it helps, I know the Title #s for the audio extras, just don't know how to get to them.
Post by d00zah »
You could try 'manual mode'. Might allow you to extract those titles? Worth a try.
https://www.makemkv.com/forum/viewtopic ... ode#p79227
bigmack3000
Looks a little daunting, but worth a shot.
Post by d00zah »
bigmack3000 wrote: Mon Nov 11, 2019 11:10 pm Looks a little daunting, but worth a shot.
No guts, no glory. The instructions even have pictures! :wink:
