John Wick: Chapter 3 - Parabellum
kevonator
Re: John Wick: Chapter 3 - Parabellum
Post by kevonator » Wed Oct 09, 2019 7:50 pm
According to process monitor .0429 mpls is correct for netflix. This is the first time I've used process monitor. I cannot confirm it's correct yet. Anybody else who knows the correct playlist for netflix? please chime in.
alephbaker
Post by alephbaker » Tue Oct 29, 2019 12:45 pm
just want to confirm for other users, using oddeyeball's method I can corroborate ChrisCaPWN is correct on the segment map for some non-retail discs. the trick being that, as far as I know, rbx and nfx both still supplement their catalogs by buying retail copies. this particular disc does not look like a rental.
Title information
Name: John Wick 3: Parabellum
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t365.mkv
rbtf70
Post by rbtf70 » Wed Oct 30, 2019 6:17 am
Want to confirm that my USA Retail version is correct with the earlier posted file:
Source file name: 00957.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
Ripped the Blu-Ray disk and played the copy on the same screen next to the DVD. Matches perfectly. 100%. Thanks for the assistance. This forum is the best!
SilentKnight09
Post by SilentKnight09 » Mon Nov 04, 2019 5:16 am
I can verify the following to be correct for the U.S. retail version (4k/Bluray combo)
Source file name: 00444.mpls
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t197.mkv
Currently using Windows10 - Java version 8 update 231.
I have noticed there are many versions of this disc many that display the correct segment map under a different File name (t197). This could be a java version related issue or just different disc versions. I would suggest updating java first and if you cant find the exact file name you will have to match by the segment map.
Hope this helps.
Lanthade
Post by Lanthade » Tue Nov 05, 2019 4:54 pm
kevonator wrote: Wed Oct 09, 2019 7:50 pm According to process monitor .0429 mpls is correct for netflix. This is the first time I've used process monitor. I cannot confirm it's correct yet. Anybody else who knows the correct playlist for netflix? please chime in.
I can confirm it was correct for the disc I got.
KiltedShane
Post by KiltedShane » Sat Nov 09, 2019 11:47 pm
I have a non-rental Netflix disc. According to Process Monitor this is the source and segment map.
Name: John Wick 3: Parabellum (English)
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
6:20:28.1552163 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00510.m2ts SUCCESS
6:20:29.6250342 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00511.m2ts SUCCESS
6:20:31.3723990 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00502.m2ts SUCCESS
6:20:32.9003049 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00505.m2ts SUCCESS
6:21:34.9833903 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00512.m2ts SUCCESS
6:21:36.0805842 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00501.m2ts SUCCESS
6:21:37.8188035 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00519.m2ts SUCCESS
6:21:38.9949787 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00516.m2ts SUCCESS
6:22:52.6964980 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00508.m2ts SUCCESS
6:22:54.1883468 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00514.m2ts SUCCESS
6:22:55.8565943 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00507.m2ts SUCCESS
6:23:59.8016667 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00515.m2ts SUCCESS
6:24:03.9659571 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00518.m2ts SUCCESS
6:24:05.5542138 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00503.m2ts SUCCESS
6:24:07.1680590 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00509.m2ts SUCCESS
6:25:15.2433734 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00504.m2ts SUCCESS
6:25:16.6718962 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00520.m2ts SUCCESS
6:25:18.4605802 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00517.m2ts SUCCESS
6:28:15.8826476 PM PowerDVDMovie.exe 12248 CloseFile G:\BDMV\STREAM\00506.m2ts SUCCESS
Geneo
Post by Geneo » Sat Nov 16, 2019 9:36 pm
What is the conclusion for a Walmart Retail Blue-Ray
Geneo
Post by Geneo » Sat Nov 16, 2019 9:50 pm
In the running are:
  • John Wick 3- Parabellum_t134-298.mpls
    John Wick 3- Parabellum_t167-429.mpls
    John Wick 3- Parabellum_t180-444.mpls
    John Wick 3- Parabellum_t380-965.mpls
    John Wick 3- Parabellum_t385-957.mpls
Geneo
Post by Geneo » Sat Nov 16, 2019 10:48 pm
Geneo wrote: Sat Nov 16, 2019 9:50 pm In the running are:
    John Wick 3- Parabellum_t167-429.mpls Not on my disc
    John Wick 3- Parabellum_t180-444.mpls On My disc this is t163-444 and does not play correctly
    John Wick 3- Parabellum_t380-965.mpls Not on my disc
Geneo
Post by Geneo » Mon Nov 18, 2019 1:34 pm
This ended up being the one that worked for me.
US Retail Target
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
File name: John Wick 3- Parabellum_t392.mkv
Geneo
Post by Geneo » Mon Nov 18, 2019 1:45 pm
SilentKnight09 wrote: Mon Nov 04, 2019 5:16 am I can verify the following to be correct for the U.S. retail version (4k/Bluray combo)
Hope this helps.
I found the 444.mpls would have a screen switch around the scene where John is sitting with Sofia on the couches. But that was with the Bluray/digital combo. Maybe not the same.
Mr_Orange
Post by Mr_Orange » Thu Dec 05, 2019 10:58 am
I just bought the Region B version from Amazon Aus and there did not appear to be any obfuscation at all. Using MakeMKV 1.14.7, only three tracks were listed and two of them were far too small to be the main feature.
It seems as though everyone else in this thread has had some sort of obfuscation to deal with. Have I messed something up?
stonkr
Post by stonkr » Sun Mar 01, 2020 10:23 am
My UK version is playlist 00696 with segment map 505,514,512,502,517,501,506,508,509,503,518,507,510,519,520,511,504,515,516.
I had to go the long way round with this one and piece together the segments in the correct order.
IrishPrince
Post by IrishPrince » Tue Jul 21, 2020 4:31 pm
US Netflix source..... Confirmed it works...
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
spoolinchaos
Post by spoolinchaos » Fri Dec 04, 2020 10:00 pm
Created an account to also confirm, using the Process Monitor, I got the following with a Netflix Blu-ray disc.
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
File name: John Wick 3: Parabellum.mkv
