I've ripped my ISO and extracted all the components via eac3to. I then created the "single layer" mp4 file using the Dolby MP4muxer command line tool.
Why could I not simply MUX this file with the Atmos TrueHD+AC3 audio component (and my Chapter and forced SRT file) into an MKV using MKVToolnix (for example). What is magical about the MP4 container EXCEPT when creating the single layer Dolby mux, for which there is no other alternative?
Or does the MKV container "UNDO" the work that the Dolby MP4Muxer did?
https://www.makemkv.com/forum/viewtopic ... 749#p79749kws53 wrote: Thu Nov 07, 2019 9:23 pm I've ripped my ISO and extracted all the components via eac3to. I then created the "single layer" mp4 file using the Dolby MP4muxer command line tool.
So I've been playing with my new Shield for the last hours and I like it. DTS-X /DTS-HD / LPCM 7.1 with single layer DV seems to work well. (got a complete freeze with Angel Heart at 2min though).
Unlike the x700, fast-forwarding worked with the titles I tried. Subtitles in SRT format also worked. No audio delay at all on my end. Shield ---> Denon AVR ----> C8
I also compared the picture with the original disc played in my x700 and I noticed a huge difference.
Colors are a lot more saturated with the Shield/Single layer. not sure of which one is right. see: https://slow.pics/comparison/4c528172-8 ... 63794b4ad3
dual-layer mp4 x700 vs original disc x700 I cant see any difference in real life.. see : https://slow.pics/comparison/8aee24ef-5 ... 4d3db147f7
more tests needed.
more tests needed.
Angryunibrow
Did you get the latest hotfix for the colorspace switching issue?RESET_9999 wrote: Fri Nov 08, 2019 1:59 am So I've been playing with my new Shield for the last hours and I like it. DTS-X /DTS-HD / LPCM 7.1 with single layer DV seems to work well. (got a complete freeze with Angel Heart at 2min though).
more tests needed.
I'm not sure if this is why the colors look different, I just know they had an issue with the colorspace switching and they released a hotfix for it.
DaMacFunkin
Hi. I’ve created a couple of these and they play well (except dts-hd track is out of synch when playing on new shield via Plex, synch is fine via Plex on my LG C7) when I mux them I’ve been muxing in the idx vob sub track, as soon as I select subs either during playback or before playback these files freeze...
Is this just that Plex is terrible at handling subs?
Or is it because I mixed the subs into the file?
Should I just have subs as an external srt?
And what about chapters, is is safe to add these to the mp4 with an header editor?
Thanks for any help with these questions.
likeadoc
@ yusesope thanks you for mentioning me
Here is a little bit of background information on the various dv profiles etc.
https://www.dolby.com/us/en/technologie ... x-v1.2.pdf
and
https://www.dolby.com/us/en/technologie ... -paper.pdf
and
https://www.dolby.com/us/en/technologie ... rkflow.pdf
and
https://developer.dolby.com/globalasset ... sguide.pdf
and
tango306 post
https://www.makemkv.com/forum/viewtopic ... &start=435
and
https://www.avsforum.com/forum/465-high ... layer.html
and
https://www.avsforum.com/forum/150-blu- ... st52706065
and
https://www.mysterybox.us/blog/2016/10/ ... -explained
@RESET_9999
Since DVDFab is essentially reverse engineering DV and there is very sparse info about DVs secret sauce, chances are very high that something is not done the proper way in their implementation :/
IMHO the only way to get the "as intended" viewing experience atm is to use a dual layer mp4:/
and
and
and
and
tango306 post
and
and
and
@RESET_9999
Gibbe21
Thanks for the reply understoodsuperfans124 wrote: Tue Nov 05, 2019 7:47 pmthis isn't alchemy, you can't make Dolby Vision out of something that doesn't have Dolby Vision to begin with...Gibbe21 wrote: Tue Nov 05, 2019 2:23 pm
Hi y'all I've was up all night and did not get this to work properly perhaps am I doing something wrong
The step I'm having issues with is the command step I always get error massage the command does not exist internal external.
And I've tried granolas app which is super nice but get error massage the movie file does not have a Dolby vision video track
The movie I'm trying with is full uhd disc Avengers infinity war
Best regards
P.s does granola have a newer version available for download I'm having version 2.0
But what if the movie I'm trying to download from private tracker have Dolby vision support according to Blu-ray.com but when I download the complete disc (untouched) it appears having only hdr10
And my next question
it may be wrong forum
But is there a great private tracker/ public tracker that have the most movies in DV
Best regards
No, I never used the colorspace match option, too many issues and since I don't watch any SDR content with the Shield, I prefer leaving the display to DV & HDR10 ready BT2020 12bits 422 23.976Angryunibrow wrote: Fri Nov 08, 2019 4:46 am
My Vertex hdfury reports bt2020 with those settings.
DaMacFunkin
Hi, does that show that the Shield can’t output 23.976 reliably? Also does that show 8 bit output,
DV is always sent in an RGB 8bit container with all my devices: x700 bluray player and the AppleTV .....so yes 8bit is normal.DaMacFunkin wrote: Fri Nov 08, 2019 4:07 pm Hi, does that show that the Shield can’t output 23.976 reliably? Also does that show 8-bit output,
https://www.avsforum.com/forum/39-netwo ... st57821152
The shield can do 23.976 properly, I don't know why hdfury reports 23.972 ... it reports 23.973 with my x700 and the appleTV (sometimes 23.974), they can both do 23.976 properly.
My HTPC with an Nvidia card cant do 23.976 properly without the custom resolution and hdfury reports 23.977 ... with custom resolution, hdfury reports 23.973.
so yes the shield is fine.
kws53
Perhaps off-topic, but why are we worried about MP4 transport, when the Transport Stream is readily available. And according to Dolby:
"A Dolby Vision stream consists of BL, EL, and RPU substreams or BL and RPU substreams. These substreams must be multiplexed into Dolby Vision VES before being fed into an MPEG-2 Transport Stream multiplexer."
Since the VES has already been multiplexed correctly for the purposes of authoring the UHD, why do we need to demux and remux into MP4? Or can we not remux the transport stream (using TSMuxer for example) into another transport stream (not touching the VES) with only the files we require (allowing for SRT addition to mitigate the need for PLEX to recode).
kws53
I did some software experimentation...
Using MI Fallout (DV + Atmos), I looked at the following:
1) Demuxing with EAC3TO - although it listed the EL as track 3, when all was demuxed, the EL layer was left behind. I could manually demux this layer later.
2) Demuxing with TSMuxer:
a) Using the Stream to demux, both the BL and EL were checked off to be demuxed.
b) Using the Playlist to demux (same length), only the BL was checked off to be demuxed.
3) Demuxing with FFMpeg - using the method in this thread, the EL and BL HEVC files were identical to the h265 files created by EAC3TO.
4) The Dolby VES muxing operation described in this thread worked flawlessly on both the BL/EL HEVC and the EAC3TO h265 files.
5) The final MP4 muxing operation (GPAC 0.80) was unsuccessful
despite having 1TB of space available on the U: drive.
despite having 1TB of space available on the U: drive.You do not have the required permissions to view the files attached to this post.
kazuma
hello,
the tool of grencola selects french & german as first language when i convert to mp4 with the movies red heat and universal soldier. this because the audio files are first selected standard audio in the container. i tryed to delete all other audio's with tsmuxer, but i get a error code. what is the solution of this?
if you dont add -tmp U:\ then C:\ is used for the temp fileskws53 wrote: Fri Nov 08, 2019 8:55 pm
5) The final MP4 muxing operation (GPAC 0.80) was unsuccessfuldespite having 1TB of space available on the U: drive.
kws53
Wasn't aware temp files were created, thank you for the explanation. Since the combined size of the files is ~85GB, I can see the issue...RESET_9999 wrote: Fri Nov 08, 2019 10:04 pmif you dont add -tmp U:\ then C:\ is used for the temp fileskws53 wrote: Fri Nov 08, 2019 8:55 pm
What exactly is the reason for a temp file anyway? We're simply muxing, aren't we?
