The Greatest Showman - video can't be decrypted
djtkneis
Post by djtkneis »
I'm having trouble opening the 4K version of "The Greatest Showman". I get the following error "The volume key is unknown for this disc - video can't be decrypted". I followed the instructions for adding the hashed keys located here: https://www.makemkv.com/forum/viewtopic ... 6959&__c=1
Here is all my info:
MakeMKV console messages:
MakeMKV v1.14.5 win(x64-release) started
Using LibreDrive mode (v05 id=64754CF46FCA)
Saved AACS dump file as
OS device name: E:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MZXJ3TF5302
Firmware date: 2116-12-20 15:28
Highest AACS version: 72
Firmware version: 1.00
Disc Information
Label: THE_GREATEST_SHOWMAN
Timestamp: 2018-02-26 13:05:17
Data capacity: 58.52 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Re: The Greatest Showman - video can't be decrypted
Posting the dump file here does not accomplish much - you need to email it to svq@makemkv.com if you want it seen by the program author as soon as possible.
st4evr
Post by st4evr »
Hash key updates have been automated for the most part. The hash key file method is not updated as often as the new method. For quicker support do as Woodstock advises.
Also, forum search function works. Use it. It will provide posts/solutions/explanations to common errors returned by MakeMKV.
https://www.makemkv.com/forum/search.ph ... is+unknown
djtkneis
Post by djtkneis »
Thanks guys. I already searched the forums and that's how I came to using the hashed keys method. I'll try sending an email to svq@makemkv.com directly.
