Chronicles of Narnia: Lion, witch wardrobe MKV file errors
bassballboy
#1 Post by bassballboy » Sat Oct 02, 2010 5:11 pm
I'm using Make MKV 1.6
I've ripped this twice now with the same result, it goes smoothly til I try to play it back, it freezess after a few seconds and crashes MPC. Any ideas?
setarip_old
Re: Chronicles of Narnia: Lion, witch wardrobe MKV file erro
#2 Post by setarip_old » Sat Oct 02, 2010 7:12 pm
Hi!
1) What version of Media Player Classic are you using?
2) Have you previously used the same version to successfully play HD MKVs?
bassballboy
#3 Post by bassballboy » Sat Oct 02, 2010 7:14 pm
setarip_old wrote:Hi!
I'll haved to check with mpc I'm using, not sure off hand.
I've had no issues with other 1080p mkv rips, have about 20 right now that I've had no problems with.
setarip_old
#4 Post by setarip_old » Sat Oct 02, 2010 11:49 pm
Just to make sure there's no confusion - when I said "HD" .MKVs, I was referring to High Definition, not HD-DVDs...
bassballboy
#5 Post by bassballboy » Sun Oct 03, 2010 9:03 pm
setarip_old wrote:Just to make sure there's no confusion - when I said "HD" .MKVs, I was referring to High Definition, not HD-DVDs...
I caught that, it's a blu-ray, straight rip (~20GB file). same as I have done with numerous other blu-rays. For some reason it does not want to play though.
