Raspberry Pi support
magisystem
Post by magisystem » Tue Jul 31, 2018 10:51 am
Hi there,
first of all, makeMkv is an awesome piece of software, thanks for keeping it up and running.
I saw that MakeMKV can be used to play Blurays in VLC and Kodi, even under Linux, which is fantastic. But I use a Raspberry Pi 3B+ (ARMv8, but I think older Pis had ARMv7 architecture) as my mediacenter, and can't install it there. Searching through the net and this forum I found some quite old posts where this topic was discussed and support for ARM anounced for a future release. So, what is the status of the ARM support?
When I can use MakeMKV to play all my Bluray discs on my Raspberry, I'd gladly pay for it.
And if you need someone to compile or test it on a Pi, I'll be glad to help.
Best regards
paulhargrave
Re: Raspberry Pi support
Post by paulhargrave » Wed Aug 15, 2018 11:51 pm
I too would really like PI support.
From [forum linux copilation instructions][https://www.makemkv.com/forum/viewtopic.php?f=3&t=224] there are 2 "packages" to compile as ARM7l
I've managed to compile the OSS files but the bin files appear to be pre-compiled as AMD64 or x86 which rather scuppers the thing.
Please please please add a ARM7l compiled binary for the front end.
Thanks!!
xhabu01
Post by xhabu01 » Thu Nov 07, 2019 6:43 am
I just attempted installing MakeMKV on my raspberry pi to find that I could not compile the Bin front end... received the error that there was no support for the ARM7 platform...
I humbly request support for the ARM platform... specifically the Raspberry PI.
Thank you for this consideration.
