Proper UHD Drive Test Procedures and Software
DVD Maniac
I was just wondering what others are using? My acid test Step 1 is will read well known fussy titles like Mockingjay. Step 2 run the usual benchmark tools like Passmark. The problem with Step 2 is I cannot find bench test SW specifically specified to include UHD. Anyone know of such free or otherwise?
Re: Proper UHD Drive Test Procedures and Software
My testing procedures are proprietary and you can't know them.DVD Maniac wrote: Wed Nov 06, 2019 7:27 pm I was just wondering what others are using? My acid test Step 1 is will read well known fussy titles like Mockingjay. Step 2 run the usual benchmark tools like Passmark. The problem with Step 2 is I cannot find bench test SW specifically specified to include UHD. Anyone know of such free or otherwise?
Lol jk
Just use makemkv to test I don't think pass mark is going to help you it won't say if it get read errors on disks.
What I do is at least 2 UHD disks with a full folder backup with known good disks and it it gets any read errors/m2ts hash errors and still does so after cleaning the disk the drive is bad often time I will double check the disk in a known good drive to make sure it didn't go bad. I also go by the read speed if the drive if it is slower than usual it is also bad.
Testing these things is 100% necessary we are lgs quality control lol I have gotten over 35 defective drives.
DVD Maniac
Lol jk
Thanks for advice
yes full folder backup with decrypt checkedDVD Maniac wrote: Thu Nov 07, 2019 1:58 am
I do use MakeMKV but just for DVD file uncompressed. I use the other, ahem, brand from our friends in Asia to backup compressed MKV;s to save drive space. Handbrake /others are flakey in my experience and tend to be riddled with Malware. Ill give it ago with MakeMKV. Do you do a folder backup or ISO?
Thanks for advice
For me if the title is supported I'll do a decrypted folder backup. Otherwise I activate libredrive and make a protected iso with imgburn that I can decrypt to folder backup once the key is released.
