superfans124
#736 Post by superfans124 » Tue Nov 05, 2019 7:47 pm
Gibbe21 wrote: Tue Nov 05, 2019 2:23 pm
Hi y'all I've was up all night and did not get this to work properly perhaps am I doing something wrong
The step I'm having issues with is the command step I always get error massage the command does not exist internal external.
And I've tried granolas app which is super nice but get error massage the movie file does not have a Dolby vision video track
The movie I'm trying with is full uhd disc Avengers infinity war
Best regards
P.s does granola have a newer version available for download I'm having version 2.0
this isn't alchemy, you can't make Dolby Vision out of something that doesn't have Dolby Vision to begin with...
DaMacFunkin
#737 Post by DaMacFunkin » Tue Nov 05, 2019 8:25 pm
Just got the latest Plex beta with my Shield Pro 2019, is there a definitive guide how to create these DV Single layer files with Atmos please?
Thank you.
Grencola
#738 Post by Grencola » Tue Nov 05, 2019 8:59 pm
Gibbe21 wrote: Tue Nov 05, 2019 2:23 pm And I've tried granolas app which is super nice but get error massage the movie file does not have a Dolby vision video track
Best regards
granola, haha :lol: Anyway thanks, and ya if it says your movie does not have dolby vision then it won't make you a file with dolby vision :P do as it says, and use a different movie.
DaMacFunkin
#739 Post by DaMacFunkin » Wed Nov 06, 2019 1:38 pm
yusesope wrote: Sun Nov 03, 2019 10:24 am
RESET_9999 wrote: Sat Nov 02, 2019 7:58 pmit works, AVR show atmos with my htpc.
FusionNeo wrote: Sun Nov 03, 2019 1:16 amThe new file you just posted has proper ATMOS support too when played back on a HTPC using your tutorial. Confirmed I am getting ATMOS audio and I was able to hear sound come out of my ATMOS speakers.
Thank you both for your feedback.
RESET_9999 wrote: Sat Nov 02, 2019 7:58 pmI tried again with a movie and it works with the htpc. i wonder why it didnt work when i tried a couple days ago(didnt update any software since then)
it's magic!
FusionNeo wrote: Sun Nov 03, 2019 1:16 amYusesope, you are the man!
Thanks but the credit also goes to the user likeadoc (look HERE).
FusionNeo wrote: Sun Nov 03, 2019 1:16 amJust tried the new Plex beta out on my Shield 2019 with your Dolby Vision DTS-X and DTS-HD MA and both files played back in Dolby Vision with DTS-X and DTS-HD MA audio.
I assume, the Single Layer files. Excellent news anyway!
FusionNeo wrote: Sun Nov 03, 2019 1:16 amThat same file will NOT play back on my NVIDIA Shield vía Plex...Do the PLEX devs need to add support?
Correct . We must inform the developers (Plex, MrMC, etc.) about the existence of this possibility and they will implement the correct decoding (as did the developers of LAV Filters).
FusionNeo wrote: Sun Nov 03, 2019 1:16 amOnce this file plays back on the SHIELD, then I would assume it would be trivial to use a Dolby Vision video track in place of the video track you used in that file for full TRUEHD + Dolby Vision support, is that correct?
Correct again. I've just updated my "HOW TO".
Hi, I have checked your guide, is there anyway to do it without dvdfab? I can’t afford this software, regards
FusionNeo
#740 Post by FusionNeo » Wed Nov 06, 2019 4:01 pm
DaMacFunkin wrote: Tue Nov 05, 2019 8:25 pm Hello,
Thank you.
FYI, Atmos filed with Dolby Vision will NOT play back on the Shield 2019. Support for that has not been added yet and would need to be added by the devs.
The best you can do, at the moment, is LPCM 7.1 (which is lossless audio, just without the Atmos metadata.)
Also, DVDFab is a requirement to making these rips. They have a proprietary way of making Single Layer Dolby Vision rips which has yet to be replicated.
#741 Post by RESET_9999 » Wed Nov 06, 2019 4:07 pm
FusionNeo wrote: Wed Nov 06, 2019 4:01 pm
Thank you.
did you try LPCM inside an mp4 container with the new Shield? it doesnt work with the old shield, no audio at all.
cardsdoc
#742 Post by cardsdoc » Wed Nov 06, 2019 5:57 pm
As has been noted Plex on the 2019 Shield supports single layer DV in a TS container as well which does have native support for HD audio. Are there any known methods to create single layer DV TS files with HD audio?
FusionNeo
#743 Post by FusionNeo » Wed Nov 06, 2019 8:03 pm
RESET_9999 wrote: Wed Nov 06, 2019 4:07 pm
Thank you.
Yes. I still need to do more testing, but audio works in LPCM. The only thing is my receiver is reporting the audio input as Dolby Digital+. Like I said, more testing is needed.
DaMacFunkin
#744 Post by DaMacFunkin » Wed Nov 06, 2019 10:58 pm
Hi Yusesope,
Followed your guide and now have a Dolby Vision back up of Casino Royale playing on shield 2019, looks stunning, but the DTS/HD is slightly out of synch, we need a way of determining the correct delay before mixing and the command to correct it - can you add this information please?
Thank you.
Angryunibrow
#745 Post by Angryunibrow » Wed Nov 06, 2019 11:28 pm
DaMacFunkin wrote: Wed Nov 06, 2019 10:58 pm Hi Yusesope,
Thank you.
I'm having the same issue, seems to be about 200ms.
I just posted in the DVDFab forums as well, as even when I create the single layer file from DVDFab using the disc audio its out of sync also.
I think this is a DVDFab issue from what I've seen, maybe someone else can chime in.
To test, create a DVDFab single layer file and play it without musing in any other audio, just leave the AC3/DTS DVDFab muxes in and see if it still out of sync.
bobross
#746 Post by bobross » Thu Nov 07, 2019 2:38 am
How can you make the MP4 with movies that only have DTS-HD or DTS Audio, not AC3?
FusionNeo
#747 Post by FusionNeo » Thu Nov 07, 2019 6:13 am
I do not have any delay when using DVDFab to rip to a single layer DV file. My first DV rip is Spider-Man: Far from Home, and it’s perfectly synced up. May want to check your settings, good on you to follow up with them in their support forum too.
As an update, I managed to fix my issue. I was using MP4Box 0.8.0 due to the new version not being available for download, and I had compiled the wrong branch by mistake (like I said, I’m still a noob to all of this.) So I am happy to report that with the latest version of MP4Box, I am getting Dolby Vision with LPCM 7.1 audio to playback on my NVIDIA Shield 2019. I have multiple audio tracks embedded as well, including the Atmos MP4 (for if/when a player is ever released for the Shield that can handle Atmos and playback Dolby Vision) and the AC3 track for maximum compatibility. For some reason, the AC3 audio track causes the entire stream to transcode though, but I would chalk this up to user error (I’m betting I’m ripping the audio incorrectly in FFMpeg) Either way, all that’s left for the purest rip possible is to get Atmos to playback in MP4 when paired with a Dolby Vision audio track, which is already proven to be possible since a HTPC can playback Atmos in MP4 without an issue. Fingers crossed this happens sooner rather than later.
bobross wrote: Thu Nov 07, 2019 2:38 am How can you make the MP4 with movies that only have DTS-HD or DTS Audio, not AC3?
The process is the same. FFMpeg is taking the audio stream you have, ripping it and encoding it into whatever format you want.
DaMacFunkin
#748 Post by DaMacFunkin » Thu Nov 07, 2019 6:59 am
Angryunibrow wrote: Wed Nov 06, 2019 11:28 pm
Thank you.
I have played this file with DTS-HD via Plex on my LG C7 oled and it is in synch (as good as damn it anyway) it is noticeably out of synch via Plex beta on new shield, so that seems to be where the problem lies.
FYI during the fab remux process I converted the DTS-HD track to AC3, the AC3 track is in synch on both Shield and LG C7.
Grencola
#749 Post by Grencola » Thu Nov 07, 2019 2:40 pm
FusionNeo wrote: Thu Nov 07, 2019 6:13 am I do not have any delay when using DVDFab to rip to a single layer DV file. My first DV rip is Spider-Man: Far from Home, and it’s perfectly synced up. May want to check your settings, good on you to follow up with them in their support forum too.
Have you tried using the custom codec for MX Player, that Yusesope made, with your shield?
FusionNeo
#750 Post by FusionNeo » Thu Nov 07, 2019 3:49 pm
Grencola wrote: Thu Nov 07, 2019 2:40 pm
Not yet, MX player can’t playback Dolby Vision and I was super invested in getting Dolby Vision playback to work properly on my Shield. Tonight I’ll give that a whirl.
