Hi!
I'm not sure if this is the right place for asking this, sorry if it's not.
I've been using this software for a couple of days and I think it's fantastic. Great idea, simple but powerful and almost perfect results. I can't say completely perfect because of the lack of support for HD-DVD subtitles.
I'd like to use this software for backing-up my HD-DVD collection, but I can't live without subtitles...
Is there any plan on fixing the problems with the subtitles?
HD-DVD subtitle support?
- Contact:
Re: HD-DVD subtitle support?
HD-DVD subtitles are fully supported. There are not so many programs that could parse them, unfortunately.
Mike do you know what programs will work with them ?
I've tried to rip some HD-DVD. VLC couldn't read the subtitles of any of those movies. Is that a problem of the player?mike admin wrote:HD-DVD subtitles are fully supported. There are not so many programs that could parse them, unfortunately.
I'll try with any other player, thanks!
try playing back with mpc-hc, it has good support for bluray/hd-dvd subs
Tried MPC-HC, no go for subtitles. Any other suggestions?
I'm going to see if my OPPO BDP83 can read them when streamed over the network later today.
