Wizard Of Oz correct playlist?
Unibrowser
#1 Post by Unibrowser » Thu Oct 31, 2019 4:04 pm
There are 2 playlists on the 4k disk. 800.mpls and 801.mpls. I am assuming one is for Dolby vision and one is for HDR10+??
This is the way
Unibrowser
Re: Wizard Of Oz correct playlist?
#2 Post by Unibrowser » Thu Oct 31, 2019 4:08 pm
There are also 3 playlists for the 1080p bluray.
100.mpls
101.mpls
000.mpls
This is the way
#3 Post by Woodstock » Thu Oct 31, 2019 5:15 pm
More likely, 00800 is the English version, and 00801 is either French or Spanish. Should only be two segments different between them.
demon
#4 Post by demon » Wed Nov 06, 2019 2:24 am
Running
mpls_dump
on the two files indicates they both point to the same
.m2ts
file, though the files are very different sizes.
eac3to
only shows the
00800.mpls
file (and
00201.mpls
, which points to
00002.m2ts
Looking at verbose output, it looks like
00801.mpls
maps out a bunch of non-English (and Japanese?) audio and PGS streams. The chapter maps appear to be the same though, so... yeah, I'm not sure why it does that.
hernanez
#5 Post by hernanez » Wed Nov 06, 2019 11:03 am
You can use bdinfo to check the differences in mpls files. Streams marked with * are not available in the specific mpls.
MakeMKV disables the * streams automatically. i.e If you choose an mpls that has certain streams disabled, they will not be available to mux.
LNK586
#6 Post by LNK586 » Sat Jun 20, 2020 11:00 am
100.mpls
101.mpls
000.mpls
Would you happen to know which track would be the one for English (100,101,000) ? Thanks in advance, I have the 75th edition 1080p Netflix
