Audio Language
vuanendientu
Audio Language
Post by vuanendientu »
I'm ripping Sharknado 4 and I'm getting no audio after ripping due to an Undetermined Audio Language. After MakeMKV scans the Blu Ray disc I see that the Language is not found. I found an post from 2009, but it didn't say if it was fixed. I'm not able to get any audio using AnyDVD 16, but can get audio in VLC. Any help would be appreciated.
Type: Audio
Language: Undetermined
Codec: DTS-HD Master Audio
Channels: 6
Channel layout: 5.1(side)
Sample rate: 48000
Bits per sample: 24
Type: Audio
Flags: Core audio
Codec: DTS
Channels: 6
Re: Audio Language
If you have set a preferred language in MakeMKV, it will only automatically select tracks tagged for that language.
Experiment with setting preferred language to "none" (the interface language is a separate setting), and see if the audio track is selected.
You can also manually select the track in "Expert mode" for when you need a specific track.
My settings are to rip all audio and subtitle tracks, regardless of language, because I will sort them out when I run handbrake to reduce the file sizes.
