Anchor Bay dvd's
Mk2548
Anchor Bay dvd's
#1 Post by Mk2548 » Sat Oct 02, 2010 12:20 am
I have a lot of Anchor Bay dvd's and all of them won't rip. I keep getting: "Copy complete. 0 titles saved, 1 failed" when I click Makemkv.
Am I the only one with this problem?
setarip_old
Re: Anchor Bay dvd's
#2 Post by setarip_old » Sat Oct 02, 2010 4:26 am
Hi!
1) How many is a lot?
2) Have you successfully processed any other DVDs with MakeMKV?
3) With "Debug" turned on, re-try one of your Anchor Bay DVDs. Submit the Debug log...
Mk2548
#3 Post by Mk2548 » Sat Oct 02, 2010 7:32 pm
I tried to copy 36 titles so far.
I've processed other dvd's (that are not from Anchor Bay) successfully.
I've submitted a few of them to the support email but here's the Debug log for Vigilante dvd:
MakeMKV v1.6.0 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\HP_Administrator/MakeMKV_log.txt
Title #0 was added (31 cell(s), 1:29:13)
Title #1 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3/2 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/1 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/2 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/3 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/4 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/10 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/11 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/12 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/13 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/14 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (2 cell(s), 0:02:13)
Title #11 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (2 cell(s), 0:03:22)
Title #14 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 was added (1 cell(s), 0:02:04)
Title #25 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Documents and Settings/HP_Administrator/Desktop
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213130490
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213129639
DEBUG: Code 0 at ^m.0&P3(7X$IY\$JhQ@:29394183
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29394160
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29395195
Failed to save title 0 to file C:/Documents and Settings/HP_Administrator/Desktop/title00.mkv
setarip_old
#4 Post by setarip_old » Sat Oct 02, 2010 11:46 pm
Just my own curiosity - As of the end of August 2010, Anchor Bay owned less than 45 titles. Why/How are you so focused on that portfolio?
Mk2548
#5 Post by Mk2548 » Sun Oct 03, 2010 12:41 am
I collected a lot of horror movies and Anchor bay use to put out some nice clean version of some classics. I wish they would continue because there still some old titles that like that haven't been issued on dvd yet.
setarip_old
#6 Post by setarip_old » Sun Oct 03, 2010 1:59 am
Thanks for the explanation about Anchor Bay ;>}
Krobar
#7 Post by Krobar » Mon Oct 04, 2010 10:58 pm
I have copied about 20 or so ABs and most were sucessful. I have quite a few of the LE tins form a few years back.
