Conspiracy (2001) "Failed to open disc"
minkiz88
#1 Post by minkiz88 » Sat Nov 02, 2019 10:38 pm
That's it, the only error. It starts reading, discovers 2 titles that have less than the threshhold length, then throws the error and stops.
Re: Conspiracy (2001) "Failed to open disc"
#2 Post by Woodstock » Sun Nov 03, 2019 4:50 am
If MakeMKV cannot find at least one title that meets your minimum title length, it will give this error.
What do you have set for the minimum?
minkiz88
#3 Post by minkiz88 » Tue Nov 05, 2019 2:30 pm
I think my drive is just dying, so it's having fun with all sorts of errors... I unplugged the drive and tried again and got the error that's like "error, logical unit is already in use" or something.
Then I unplugged and tried AGAIN and it loaded after a couple minutes and a few dozen "Region setting of drive xxx does not match the region of currently inserted disc, trying workaround" until it worked. O.o
Looks like I should be getting a new blu ray drive for Black Friday?
minkiz88
#4 Post by minkiz88 » Tue Nov 05, 2019 6:08 pm
Also, to avoid creating another thread, I'm getting a series of errors ~25 minutes into ripping another movie (Runaway Jury, blu-ray):
OS error - STATUS_DEVICE_DATA_ERROR occurred while reading '\Device\CdRom0' at offset '10514135040',
a couple of these - Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10504697856',
and a few of these - Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10514135040'.
Does this all point to my drive going bad?
