Conspiracy (2001) "Failed to open disc"
minkiz88
That's it, the only error. It starts reading, discovers 2 titles that have less than the threshhold length, then throws the error and stops.
Re: Conspiracy (2001) "Failed to open disc"
If MakeMKV cannot find at least one title that meets your minimum title length, it will give this error.
What do you have set for the minimum?
minkiz88
I think my drive is just dying, so it's having fun with all sorts of errors... I unplugged the drive and tried again and got the error that's like "error, logical unit is already in use" or something.
Then I unplugged and tried AGAIN and it loaded after a couple minutes and a few dozen "Region setting of drive xxx does not match the region of currently inserted disc, trying workaround" until it worked. O.o
Looks like I should be getting a new blu ray drive for Black Friday?
minkiz88
Also, to avoid creating another thread, I'm getting a series of errors ~25 minutes into ripping another movie (Runaway Jury, blu-ray):
OS error - STATUS_DEVICE_DATA_ERROR occurred while reading '\Device\CdRom0' at offset '10514135040',
a couple of these - Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10504697856',
and a few of these - Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '10514135040'.
Does this all point to my drive going bad?
