Conversion process not starting
dtjones369
Post by dtjones369 » Fri Nov 01, 2019 11:55 pm
Good evening.
I thought it was 1 disk, but it is happening to others now.
Load disk, MakeMKV recognizes it, analyzes it and allows me to check the file I want converted. I click the start button and it does the initial quick pass, but never starts converting. I have even left it for an hour and nothing.
First happened to The Bone Collector disk, but I did several before and after.
Today I did the first 4 Harry Potter movies, but the last 4 won't convert.
I am using the latest version and have tried it on both mac and pc. My pc has 4 cd/dvd drives and I have tried them all.
Is anyone else having this issue? Is there a fix?
I have converted the Harry Potter movies before, direct thru Handbrake. Just wanted to update the audio, so was doing it again which led me to this issue.
Thank you.
Re: Conversion process not starting
Post by Woodstock » Sat Nov 02, 2019 12:07 am
Do you have debug logging turned on? Are any errors reported?
Without more information, the best answer we can give is, "Sounds like it's broken."
dtjones369
Post by dtjones369 » Sat Nov 02, 2019 3:08 am
I did 5 other disks today.
No errors come up. Just never gets going.
Maybe I will trying converting the whole disk instead of just my single selection.
Djames516
Post by Djames516 » Thu Nov 14, 2019 1:26 am
I had a similar issue.
https://www.makemkv.com/forum/viewtopic.php?f=7&t=20326
This seemed to fix it for me.
