Re: LIBMKV_TRACE: Exception: Error while reading input
Yes, it's the same error. Please send IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6 . The problem is with audio track, please try to figure out which one causes the problem.
smckenzie
Here's to examples for you, Ransom and The Thing.
1. Ransom
Doesn't error after clicking MakeMKV and does start the extraction, but it doesn't finish and ends up with the same error. Does the same an all audio tracks.
2. The Thing
Errors straight away after clicking MakeMKV. Does the same an all audio tracks.
IFO and logs attached.
1. Ransom
2. The Thing
Schimanski
Hello everybody,
I also get this error, but since I can not find any older versions of makemkv
I can not test, if it is an error, which just came up with the new version.
This happens no matter if from the original DVD, or from a ripped version,
as long as I do not choose any audio it works.
I?m on Win7 64bit.
BR
Schimmi
EDIT:
Found Version 1.5.4 and it works like a charm, so something must have changed from that version,
can not tell when it did change, since I only found version 1.5.4
I?m on Win7 64bit.
BR
Schimmi
EDIT:
Confirmed problem, will be corrected in a next version.
mrgenie
Running version 1.7.8. here and also have this error popping up..mike admin wrote:Confirmed problem, will be corrected in a next version.
