I plan on doing some testing this weekend. However, the Plex beta still isn't pushed to my SHIELD. Beyond that there are a handful of bugs that nVidia is working on fixing, as well. I think the early stages here are going to be problematic but hopefully things improve.
Would you be willing to side load the beta? The apk is available in the release announcement on the Plex forumsSamuriHL wrote: ↑Fri Nov 01, 2019 2:45 pmI plan on doing some testing this weekend. However, the Plex beta still isn't pushed to my SHIELD. Beyond that there are a handful of bugs that nVidia is working on fixing, as well. I think the early stages here are going to be problematic but hopefully things improve.
i beg to remark, that LG OLED tv's and x700 are certified by Dolby Labs, madVR and Mediainfo are not.RESET_9999 wrote: ↑Fri Nov 01, 2019 1:22 pmas I said here: https://www.makemkv.com/forum/viewtopic ... 690#p80363
it's not just about triggering DV.
Hello friends!
Who wants some TrueHD/ATMOS inside an mp4?
I don't have an AVR available right now so I don't know if ATMOS metadata has been preserved.
By simulating an audio output on Windows I can state that the TrueHD stream has been correctly integrated into the mp4 container.
If someone wants to do some tests, I attach a sample file (HERE).
To play the file and allow the Bitstream passthrough you have to use the LAV Filters (I used the version 0.74.1-29 Nightly) and MPC-BE (v 1.5.3).
Follow the tutorial you find HERE.
For those who ask: "Why does mediainfo show only two channels?"
Greetings to all and see you soon.
did you use the latest ffmpeg to create the mp4 from atmos?yusesope wrote: ↑Fri Nov 01, 2019 5:48 pmHello friends!
Because I also tried that(i try every time there is a new version) and it wouldn't bitstream atmos to my AVR but it played correctly in mpc(showing 7.1channels) when lavfilter bitstream is unchecked.
and unlike an mp4/DTS-X, my Oled tv was unable to play the audio.
I'm still going to try your sample. thanks!
Yep!RESET_9999 wrote: ↑Fri Nov 01, 2019 7:14 pmdid you use the latest ffmpeg to create the mp4 from atmos?
The important thing is that the LAV Audio Decoder is able to process the TrueHD stream.RESET_9999 wrote: ↑Fri Nov 01, 2019 7:14 pmBecause I also tried that(i try every time there is a new version) and it wouldn't bitstream atmos to my AVR but it played correctly in mpc(showing 7.1channels) when lavfilter bitstream is unchecked.
As you say, mpc recognizes the stream: this is potentially a fantastic news for those who own or who will buy the new Shield TV.
The PLEX Client is in fact based on the ExoPlayer library which can be associated with FFmpeg (compiled for Android).
Let me Know.
Guys,
I have used the below command to merge/rip the video tracks from 4K Disk m2ts file. But after ripping I found there are still two tracks are there. Any help?
In my LG 49UH75 TV, other DV demo files are playing correctly. When I try to play this kind of file then entire screen is greenish.
Command (I did not include audio track intentionally) - "G:\test\dlb_mp4base-master\bin\mp4muxer_64bits.exe --dv-profile 7 --input-file G:\test\00234.track_4113.hevc --input-file G:\tesyyy\00234.track_4117.hevc --output-file H:\dv_video.mp4"
Thanks...
Thanks...
- dv.JPG (34.93 KiB) Viewed 24648 times
- 20191102_090733_01.jpeg (1.33 MiB) Viewed 24648 times
sounds like the same issue the LG C6 has with certain movies (4000nits P3 movies i think).lifeolife wrote: ↑Sat Nov 02, 2019 3:55 amGuys,
Thanks...
I have tried your sample on X700 and unfortunately the audio does not work :/yusesope wrote: ↑Fri Nov 01, 2019 5:48 pmHello friends!
I have the new Shield 2019 Pro, I will test it when I’m home. If this works you have no idea how happy I’ll be!
I repeat myself:
the only way to play the file is to use a PC with MPC + LAV Filters.
To test everything:
PC --> HDMI --> AVR.
The file cannot work on any other device (TV, BD Player, Console, etc.)
At the moment I don't have an AVR available and therefore I can't say that the metadata has been stored correctly.
If the file works, then all that remains is to implement FFmpeg on a device capable of reproducing
Dolby Vision movies (ex: Shield TV 2019)
it works, AVR show atmos with my htpc.
Oled cant play the file at all. no video/audio
I tried again with a movie and it works with the htpc. i wonder why it didnt work when i tried a couple days ago(didnt update any software since then)
this one plays on the oled without audio (say unsupported)
Yusesope, you are the man!
Just tried the new Plex beta out on my Shield 2019 with your Dolby Vision DTS-X and DTS-HD MA and both files played back in Dolby Vision with DTS-X and DTS-HD MA audio.
The new file you just posted has proper ATMOS support too when played back on a HTPC using your tutorial. Confirmed I am getting ATMOS audio and I was able to hear sound come out of my ATMOS speakers.
That same file will NOT play back on my NVIDIA Shield vía Plex, it says my server has been disconnected, but when looking at playback info it says the audio is attempting to transcode due to the audio codec not being in a compatible container. I’m kind of a noob, so what’s left to get this file playing back properly on the SHIELD? Does Android need to support it? Do the PLEX devs need to add support?
Once this file plays back on the SHIELD, then I would assume it would be trivial to use a Dolby Vision video track in place of the video track you used in that file for full TRUEHD + Dolby Vision support, is that correct?
Thanks again for all of your hard work. Amazing stuff.
Thank you both for your feedback.
it's magic!RESET_9999 wrote: ↑Sat Nov 02, 2019 7:58 pmI tried again with a movie and it works with the htpc. i wonder why it didnt work when i tried a couple days ago(didnt update any software since then)
Thanks but the credit also goes to the user likeadoc (look HERE).
I assume, the Single Layer files. Excellent news anyway!
Correct . We must inform the developers (Plex, MrMC, etc.) about the existence of this possibility and they will implement the correct decoding (as did the developers of LAV Filters).
Correct again. I've just updated my "HOW TO".
