Post by SamuriHL »
Ok, well, if we can't get a clean DV source to play through the SHIELD then we have a larger problem. I don't particularly feel like rolling them by hand with the tools in this thread, either. This whole thing is academic for me because 1) I couldn't care less about DV on UHD rips because I use madvr on a 2070, 2) I have the UB820 to play the original DV if I ever wanted to. I just find this topic fascinating and it'd be neat to see it work. I bought the new SHIELD for DV, yes, but, for streaming services where I feel DV makes a HUGE impact. (I can't drive that through madvr without buying a $5k Envy and I'm not doing that). In any case I'm watching that thread now so if progress is made there I'll bite the bullet and make myself a proper single layer DV mp4 or go find a free demo one to play with. This thing was just released so I suspect it's going to improve over time.
P.S. Your English is quite good and I can perfectly understand what you're saying. :)
superfans124
Post by superfans124 »
RESET_9999 wrote: Sat Oct 05, 2019 1:11 am
yeah, angel heart(crash) and life of pets 2(stutter) is a no go, I had to watch them in HDR10.
but I watched more than 40 DV LPCM movies with the X700 without issue. I have almost the same setup you have, I'm surprised that most of your DV remux freeze your player.
x700 ----> Denon AVR ----> C8
this is the cmd-line I used for all my remux:
maybe you already knew this, but I gave Angel Heart another shot, I mp4boxed in just the commentary ac3 track, and the dual layer mp4 plays smoothly over x700. that got me excited for a moment, then I mp4boxed in the converted lpcm, kaput...it still won't play, but it's not the "typical freeze-of-death", the screen froze but I was able and pull back to the previous menu. I don't know what conclusions can be drawn from these observations...
superfans124 wrote: Thu Oct 31, 2019 1:26 am maybe you already knew this, but I gave Angel Heart another shot, I mp4boxed in just the commentary ac3 track, and the dual layer mp4 plays smoothly over x700. that got me excited for a moment, then I mp4boxed in the converted lpcm, kaput...it still won't play, but it's not the "typical freeze-of-death", the screen froze but I was able and pull back to the previous menu. I don't know what conclusions can be drawn from these observations...
oh really. I'm pretty sure that I tried that too and it still refused to play. And Yes I think I was also able to stop the video.
might give this movie another try then. :)
BTW, I have Don't look now in DV/AC3, and it plays fine. so it could be the same issue.
MastaG
Post by MastaG »
Also still waiting for a player which supports a format which can carry HD-audio (e.g. LPCM inside mp4-container) and DV, I hope the new Shield will make it possible.
Or find a way to mux ac3+/truehd + atmos into a mp4 container.
Now something else.. I heard there's a two kinds of DV dual-layer movies?
Those which only have DV metadata in the second layer and those with a full 1080p video track, is this true?
If yes, can someone recommend me a DV movie which has a full video track? (or a list perhaps).
daddy
Post by daddy »
There is 2 kinds of DV.
FEL : Full Enhancement Layer
MEL : Minimal Enhancement Layer
from: https://www.dolby.com/us/en/technologie ... rkflow.pdf
The base layer essence is a 10-bit video bitstream of the full picture element with HDR10
standards that enables compatibility with HDR10 devices.
The enhancement layer essence is a 10-bit video bitstream that carries the residual between the
mezzanine source and the base layer and the dynamic metadata for Dolby Vision.
• An enhancement layer that carries a residual signal equal to zero, that is, the decoder does not
need to process the residual signal, is called minimum enhancement layer (MEL).
• If the enhancement layer carries a residual signal not equal to zero, it is called full
enhancement layer (FEL).
5.2.1.1 MEL recommendations
In the following base layer and MEL bitrate allocation recommendations, the ratio between base layer and
MEL are fixed and scaled linearly based on the total bitrate target.
• Bitrate ratio: (98% base layer and 2% MEL) to (99.5% base layer and 0.5% MEL)
• Recommended defaults for a total 100 Mbps:
o Base layer: 99.5 Mbps
o MEL: 0.5 Mbps
• Recommended defaults for a total 50 Mbps:
o Base layer: 49.75 Mbps
o MEL: 0.25 Mbps
5.2.1.2 FEL recommendation
In the following base layer and FEL bitrate allocation recommendations, the ratio between base layer and
FEL are fixed and scaled linearly based on the total bitrate target.
• Bitrate ratio: (80% base layer and 20% FEL) to (95% base layer and 5% FEL)
o Base layer: 85 Mbps
o FEL: 15 Mbps
o Base layer: 42 Mbps
o FEL: 8 Mbps
FEL exemple: Gladiator (HEVC Video 6826 kbps)
DISC INFO:
Disc Title:     Gladiator.2000.MULTI.COMPLETE.UHD.BLURAY-EXTREME
Disc Size:      92,459,896,796 bytes
Protection:     AACS2
BD-Java:        Yes
Extras:         Ultra HD
BDInfo:         0.5.8.7 (compatible layout created by DVDFab 10.0.8.4)
PLAYLIST REPORT:
Length:                 2:50:56.495 (h:m:s.ms)
Total Bitrate:          61.65 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       43319 kbps          2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 /
* MPEG-H HEVC Video     6826 kbps           1080p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
AUDIO:
Codec                           Language        Bitrate         Description
DTS:X/DTS-HD Master Audio       English         3821 kbps       7.1-X / 48 kHz / 3821 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       English         256 kbps        2.0 / 48 kHz / 256 kbps / 24-bit
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Russian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Czech           768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
* DTS Audio                     Russian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         22.751 kbps
Presentation Graphics           French          22.029 kbps
Presentation Graphics           Dutch           19.562 kbps
Presentation Graphics           Danish          20.985 kbps
Presentation Graphics           Finnish         20.635 kbps
Presentation Graphics           Norwegian       20.407 kbps
Presentation Graphics           Swedish         20.529 kbps
Presentation Graphics           Czech           20.365 kbps
Presentation Graphics           Greek           23.529 kbps
Presentation Graphics           English         71.169 kbps
Presentation Graphics           French          60.246 kbps
Presentation Graphics           Russian         66.866 kbps
Presentation Graphics           Greek           66.406 kbps
Presentation Graphics           French          0.28 kbps
Presentation Graphics           Russian         0.363 kbps
Presentation Graphics           Czech           0.291 kbps
* Presentation Graphics         French          54.234 kbps
* Presentation Graphics         Russian         65.151 kbps
* Presentation Graphics         English         62.795 kbps
* Presentation Graphics         Greek           63.312 kbps
FEL example: Casino royale (HEVC Video 65 kbps)
DISC INFO:
Disc Title:     Casino.Royale.2006.MULTI.COMPLETE.UHD.BLURAY-COASTER
Disc Size:      66,054,739,138 bytes
Protection:     AACS2
Extras:         Ultra HD, BD-Java
BDInfo:         0.7.5.5
PLAYLIST REPORT:
Length:                 2:24:33.289 (h:m:s.ms)
Total Bitrate:          56.17 Mbps
VIDEO:
MPEG-H HEVC Video       41863 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
* MPEG-H HEVC Video     65 kbps             1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / Dolby Vision / BT.2020
AUDIO:
DTS-HD Master Audio             English         3887 kbps       5.1 / 48 kHz /  3887 kbps / 24-bit (DTS Core: 5.1 / 48 kHz /   768 kbps / 24-bit)
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz /   768 kbps / 24-bit
DTS Audio                       German          768 kbps        5.1 / 48 kHz /   768 kbps / 24-bit
DTS Audio                       Italian         768 kbps        5.1 / 48 kHz /   768 kbps / 24-bit
Dolby Digital Audio             Czech           448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
Dolby Digital Audio             Hungarian       448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
Dolby Digital Audio             Polish          448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
* DTS Audio                     Japanese        768 kbps        5.1 / 48 kHz /   768 kbps / 24-bit
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz /   224 kbps / DN -31dB
SUBTITLES:
* Presentation Graphics         Japanese        13.574 kbps
Presentation Graphics           English         19.883 kbps
Presentation Graphics           Spanish         18.333 kbps
Presentation Graphics           French          15.722 kbps
Presentation Graphics           Spanish         18.297 kbps
Presentation Graphics           Danish          17.557 kbps
Presentation Graphics           Dutch           18.547 kbps
Presentation Graphics           Finnish         16.318 kbps
Presentation Graphics           German          17.414 kbps
Presentation Graphics           Italian         20.254 kbps
Presentation Graphics           Norwegian       15.101 kbps
Presentation Graphics           Swedish         15.268 kbps
Presentation Graphics           Chinese         16.882 kbps
Presentation Graphics           Czech           17.940 kbps
Presentation Graphics           Hungarian       15.397 kbps
Presentation Graphics           Korean          9.624 kbps
Presentation Graphics           Chinese         13.983 kbps
Presentation Graphics           Polish          15.657 kbps
Presentation Graphics           Portuguese      19.190 kbps
Presentation Graphics           English         69.850 kbps
Presentation Graphics           French          61.988 kbps
Presentation Graphics           Spanish         65.461 kbps
Presentation Graphics           German          70.091 kbps
Presentation Graphics           Italian         70.029 kbps
* Presentation Graphics         Japanese        0.993 kbps
* Presentation Graphics         Japanese        0.987 kbps
* Presentation Graphics         Japanese        40.844 kbps
astephon88
Post by astephon88 »
FYI, Dolby Vision wasn't actually enabled in the beta release. Should be fixed now.
https://forums.plex.tv/t/dolby-vision-n ... astephon88
Chipless
Post by Chipless »
Late to the party here, so please have patience with me as I am trying to get caught up. Before investing too much time into research, I figured I would ask those of you who have been working to get the Dolby Vision and Atmos combination to work consistently using something like Plex:
Would you consider it worth the effort to setup Plex via an HTPC rather than play UHD disc backups via an Oppo connected to an external hard drive (which is what I've been doing and has been working flawlessly)? The disc backup/Oppo method is very easy and consistent, but obviously the interface of the Oppo isn't the best, and having to unplug/plug in several different external hard drives into the Oppo isn't the most ideal way to browse a movie collection :|
Post by SamuriHL »
astephon88 wrote:FYI, Dolby Vision wasn't actually enabled in the beta release. Should be fixed now.
Haha gotta love feature flags lmao
sajtipajti
Post by sajtipajti »
Good news:
Latest DVDFab 11 can convert a MEL UHD BR to a working single layer DV mp4 file with HR audio (eg. DTS HD-MA).
General
Complete name                            : G:\WORK\Video\Spectre.2015\SPECTRE.Title800.mp4
Commercial name                          : HDR10
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/isom/dby1)
File size                                : 46.0 GiB
Duration                                 : 2 h 28 min
Overall bit rate                         : 44.5 Mb/s
Movie name                               : Spectre
Performer                                : Sam Mendes
Performer/Sorted by                      : Sam Mendes
Genre                                    : Action & Adventure & Crime
Description                              : A cryptic message from Bond’s past sends him on a trail to uncover a sinister organization. While M battles political forces to keep the secret service alive, Bond peels back the layers of deceit to reveal the terrible truth behind SPECTRE.
Encoded date                             : UTC 2019-10-31 20:30:09
Tagged date                              : UTC 2019-10-31 21:13:22
Writing application                      : DVDFab 11.0.5.6
Cover                                    : Yes
Title/Sort                               : Spectre
LongDescription                          : A cryptic message from Bond’s past sends him on a trail to uncover a sinister organization. While M battles political forces to keep the secret service alive, Bond peels back the layers of deceit to reveal the terrible truth behind SPECTRE.
Video
Dolby Vision                             : 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 42.5 Mb/s
Bits/(Pixel*Frame)                       : 0.214
Stream size                              : 44.0 GiB (96%)
Encoded date                             : UTC 2019-10-31 20:30:23
Tagged date                              : UTC 2019-10-31 21:13:21
Audio #1
Format                                   : DTS
Codec ID                                 : dtsc
Codec ID/Info                            : Digital Theater Systems
Bit rate                                 : 1 509 kb/s
Sampling rate                            : 0 Hz
Bit depth                                : 28 bits
Stream size                              : 1.56 GiB (3%)
Title                                    : English (dts 5.1)
Tagged date                              : UTC 2019-10-31 21:13:20
Audio #2
Codec ID                                 : ac-3
Bit depth                                : 16 bits
Stream size                              : 475 MiB (1%)
Title                                    : Hungarian (ac3 5.1)
Language                                 : Hungarian
sajtipajti wrote: Thu Oct 31, 2019 9:40 pm Good news:
mmm I just tried the latest version and I still get both HDR10 & DV in profile 5 which i think, can't be right.
How come your MediaInfo is different? is it up to date? mine is the latest version.
Is it because I use the trial version of DVDFAB ?
and btw your audio is lossy dts, you still need mp4box to add lossless audio.
sajtipajti
RESET_9999 wrote: Thu Oct 31, 2019 11:48 pm mmm I just tried the latest version and I still get both HDR10 & DV in profile 5 which i think, can't be right.
My LG OLLED tv recognized it as Dolby Vision.
RESET_9999 wrote: Thu Oct 31, 2019 11:48 pm How come your MediaInfo is different? is it up to date? mine is the latest version.
Mine is 18.12
RESET_9999 wrote: Thu Oct 31, 2019 11:48 pm and btw your audio is lossy dts, you still need mp4box to add lossless audio.
Unfortunately you are right, last evening I was very happy, and unobservant. :(
sajtipajti wrote: Fri Nov 01, 2019 4:35 am My LG OLLED tv recognized it as Dolby Vision.
as I said here: https://www.makemkv.com/forum/viewtopic ... 690#p80363
it's not just about triggering DV.
Post by SamuriHL »
I plan on doing some testing this weekend. However, the Plex beta still isn't pushed to my SHIELD. Beyond that there are a handful of bugs that nVidia is working on fixing, as well. I think the early stages here are going to be problematic but hopefully things improve.
astephon88
SamuriHL wrote: Fri Nov 01, 2019 2:45 pm I plan on doing some testing this weekend. However, the Plex beta still isn't pushed to my SHIELD. Beyond that there are a handful of bugs that nVidia is working on fixing, as well. I think the early stages here are going to be problematic but hopefully things improve.
Would you be willing to side load the beta? The apk is available in the release announcement on the Plex forums
sajtipajti
RESET_9999 wrote: Fri Nov 01, 2019 1:22 pm as I said here: https://www.makemkv.com/forum/viewtopic ... 690#p80363
i beg to remark, that LG OLED tv's and x700 are certified by Dolby Labs, madVR and Mediainfo are not.
