Wizard Of Oz correct playlist?
Unibrowser
Post by Unibrowser »
There are 2 playlists on the 4k disk. 800.mpls and 801.mpls. I am assuming one is for Dolby vision and one is for HDR10+??
This is the way
Unibrowser
Re: Wizard Of Oz correct playlist?
There are also 3 playlists for the 1080p bluray.
100.mpls
101.mpls
000.mpls
This is the way
More likely, 00800 is the English version, and 00801 is either French or Spanish. Should only be two segments different between them.
demon
Post by demon »
Running
mpls_dump
on the two files indicates they both point to the same
.m2ts
file, though the files are very different sizes.
eac3to
only shows the
00800.mpls
file (and
00201.mpls
, which points to
00002.m2ts
Looking at verbose output, it looks like
00801.mpls
maps out a bunch of non-English (and Japanese?) audio and PGS streams. The chapter maps appear to be the same though, so... yeah, I'm not sure why it does that.
hernanez
Post by hernanez »
You can use bdinfo to check the differences in mpls files. Streams marked with * are not available in the specific mpls.
MakeMKV disables the * streams automatically. i.e If you choose an mpls that has certain streams disabled, they will not be available to mux.
LNK586
Post by LNK586 »
Unibrowser wrote: Thu Oct 31, 2019 4:08 pm There are also 3 playlists for the 1080p bluray.
100.mpls
101.mpls
000.mpls
Would you happen to know which track would be the one for English (100,101,000) ? Thanks in advance, I have the 75th edition 1080p Netflix
