Wizard Of Oz correct playlist?
Unibrowser
There are 2 playlists on the 4k disk. 800.mpls and 801.mpls. I am assuming one is for Dolby vision and one is for HDR10+??
This is the way
Unibrowser
Re: Wizard Of Oz correct playlist?
There are also 3 playlists for the 1080p bluray.
100.mpls
101.mpls
000.mpls
100.mpls
101.mpls
000.mpls
This is the way
More likely, 00800 is the English version, and 00801 is either French or Spanish. Should only be two segments different between them.
demon
Running on the two files indicates they both point to the same file, though the files are very different sizes. only shows the file (and , which points to ).
Looking at verbose output, it looks like maps out a bunch of non-English (and Japanese?) audio and PGS streams. The chapter maps appear to be the same though, so... yeah, I'm not sure why it does that.
mpls_dumpCode: Select all
.m2tsCode: Select all
eac3toCode: Select all
00800.mplsCode: Select all
00201.mplsCode: Select all
00002.m2tsLooking at verbose output, it looks like
00801.mpls-
hernanez
You can use bdinfo to check the differences in mpls files. Streams marked with * are not available in the specific mpls.
MakeMKV disables the * streams automatically. i.e If you choose an mpls that has certain streams disabled, they will not be available to mux.
LNK586
Unibrowser wrote: Thu Oct 31, 2019 4:08 pm There are also 3 playlists for the 1080p bluray.
100.mpls
101.mpls
000.mpls
Would you happen to know which track would be the one for English (100,101,000) ? Thanks in advance, I have the 75th edition 1080p Netflix
