Scary Stories To Tell In The Dark
hvnphoto
Post by hvnphoto »
Title information
Name: Scary Stories To Tell in the Dark
Source file name: 00261.mpls
Duration: 1:47:57
Chapters count: 16
Segment count: 15
Segment map: 507,510,511,504,503,515,506,508,501,513,514,502,512,509,505
File name: Scary Stories To Tell in the Dark_t91.mkv
Steveredrum
Re: Scary Stories To Tell In The Dark
Post by Steveredrum »
hvnphoto wrote: Mon Oct 28, 2019 4:33 pm Title information
Duration: 1:47:57
Chapters count: 16
Segment count: 15
Thanks I second this PLAYLIST thanks
ChrisCaPWN
Post by ChrisCaPWN »
Original Post - I disagree with 00261.mpls as being accurate. I am watching my backup, and around the 31 minute mark it definitely had some scene jumping. I am now watching it off the disc, and that confirms that 261 is not the correct playlist. I will be going line by line to find the correct playlist this weekend. I will post an update once I have completed that.
Update - I stand corrected, I checked the segment map with Process Monitor, and 00261.mpls IS correct. My initial problem was that MakeMKV tags 00282.mpls as the FPL_MainFeature, which is incorrect. I'm glad I figured out the confusion I was having, and also glad to confirm 00261.mpls is correct!
Steveredrum
ChrisCaPWN wrote: Fri Nov 01, 2019 1:09 am I disagree with 00261.mpls as being accurate. I am watching my backup, and around the 31 minute mark it definitely had some scene jumping. I am now watching it off the disc, and that confirms that 261 is not the correct playlist. I will be going line by line to find the correct playlist this weekend. I will post an update once I have completed that.
Bad Film Editing maybe but it plays perfect using [00261.mpls] all so checked via a muxed version of the Film
chapter by chapter and everything seems Tickety Boo to me
https://youtu.be/kzVCahrtaWI
ChrisCaPWN
Steveredrum wrote: Sun Nov 03, 2019 3:19 am
lebelm
Post by lebelm »
Is 261 correct for Redbox version as well?
hvnphoto
Post by hvnphoto »
lebelm wrote: Tue Nov 05, 2019 12:36 pm Is 261 correct for Redbox version as well?
If you have playlist 261 and the segments match then you're good.
Damundai
Post by Damundai »
REDBOX VERSION:
Title information
Source file name: 00298.mpls
Duration: 1:47:57
Chapters count: 16
Segment count: 15
Segment map: 504,511,512,509,510,513,514,508,507,502,501,506,515,503,505
File name: Scary Stories To Tell in the Dark_t137.mkv
This was playing the original Blu-Ray using PowerDVD and using Process Monitor to sniff it out.
Also confirmed by watching the rip. This is the right mpls for the Redbox version.
tobunk
Post by tobunk »
Anyone figured out the Netflix (US) version yet? the segment maps for 298 and 261 do not match what I see here.
tobunk
Post by tobunk »
tobunk wrote: Wed Nov 06, 2019 9:59 pm Anyone figured out the Netflix (US) version yet? the segment maps for 298 and 261 do not match what I see here.
disregard, look like 298 is correct for Netflix.
starfish
Post by starfish »
I have 2 for Netflix
Title information
Name: Scary Stories To Tell in the Dark (English)
Comment: SPBD Copy Disclaimer Playlist
Source file name: 00441.mpls
Duration: 1:48:57
Chapters count: 16
Segment count: 16
Segment map: 504,2861,501,508,515,505,509,507,514,510,512,513,506,503,511,502
File name: Scary Stories To Tell in the Dark-SPBD Copy Disclaimer Playlist_t00.mkv
title information
Comment: FPL_MainFeature
Source file name: 00942.mpls
Duration: 1:47:57
Chapters count: 16
Segment count: 15
Segment map: 504,509,512,511,510,514,513,507,502,501,508,506,515,503,505
File name: Scary Stories To Tell in the Dark-FPL_MainFeature_t19.mkv
NutFlush920
Post by NutFlush920 »
Damundai wrote: Tue Nov 05, 2019 2:31 pm REDBOX VERSION:
Title information
Duration: 1:47:57
Chapters count: 16
Segment count: 15
With my Redbox version 00298.mpls matches your Segment Map however, the File name is t121. T137 is 00342.mpls.
Is it safe to assume all that matters is the correct segment map and source file name?
Post by d00zah »
NutFlush920 wrote: Fri Nov 08, 2019 10:17 pm
Title information
Duration: 1:47:57
Chapters count: 16
Segment count: 15
Filenames will vary depending on the value set for "Minimum title length (seconds)" in preferences. The .mpls is the thing look to for a given release version..
NutFlush920
d00zah wrote: Fri Nov 08, 2019 10:28 pm
Title information
Duration: 1:47:57
Chapters count: 16
Segment count: 15
ejfigueroa1978
Post by ejfigueroa1978 »
can someone help walk me through putting the chapters in order and how to find the main file for Red Box version Blu ray?
